type 4 line bore, I need a line bore in tucson az. |
goobstine |
Aug 21 2020, 10:23 PM
Newbie Group: Members Posts: 30 Joined: 10-February 20 From: tucson az. Member No.: 23,908 Region Association: None |
will a type 4 vanagon crank slip into a type 4 914 case?
will a 2.0 crank fit into a 1.7 case with out machining ? will a 200 mm flywheel and pressure plate that is made to fit type 4 crank work okay with 1.7 thru 2.0 ? will 215mm flywheel from bus be okay with 914 transmission ? bus crank has pilot bearing in shaft 914 has in flywheel how do i go about using bus crank in 914 engine thank you ! |
Lo-Fi Version | Time is now: 25th April 2024 - 02:27 PM |
