type 4 line bore, I need a line bore in tucson az. |
goobstine |
Aug 21 2020, 10:23 PM
Newbie Group: Members Posts: 30 Joined: 10-February 20 From: tucson az. Member No.: 23,908 Region Association: None |
will a type 4 vanagon crank slip into a type 4 914 case?
will a 2.0 crank fit into a 1.7 case with out machining ? will a 200 mm flywheel and pressure plate that is made to fit type 4 crank work okay with 1.7 thru 2.0 ? will 215mm flywheel from bus be okay with 914 transmission ? bus crank has pilot bearing in shaft 914 has in flywheel how do i go about using bus crank in 914 engine thank you ! |
914e |
Aug 22 2020, 03:03 PM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
You might see if the people at Chirco can recommend Tucson machine shop.
goobstine |
Aug 26 2020, 11:21 PM
Already did. That is why I am here. Chirco wanted a huge slice of that pie. I can get the job done through another builder for between 100 and 125. but cant get the name of the guy who comes to tucson once a month to pick up the cases and does the work. everybody has there hand in it. I have a couple hand fulls of type 4 engines about 20. If i find this guy we both be happy. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 25th April 2024 - 06:21 PM |
