Dominic |
Dominic ![]() ![]() ![]() Group: Members Posts: 993 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California ![]() |
SOLD!
NEW (never installed) Tangerine Racing Oil Pressure Relief Valve: $75.00 obo includes free shipping in CONUS (These now cost $95.00) SOLD! http://www.tangerineracing.com/oilpressurerelief.htm Our pressure relief valve replaces the stock assembly located in the bottom of the Type 4 engine crankcase. It eliminates the oil cooler bypass in the stock oil circuit and raises the peak operating pressure to 70psi.The crankcase bore for the pressure relief assembly is well worn after 40 years of operation and often bypasses a significant amount of oil, lowering available pressure to the bearings. Our assembly uses a chrome-moly steel sleeve with close tolerance stainless steel piston for many years of troublefree performance. It will cure many high oil temp/low oil pressure issues and is essential for modified engines with external oil coolers - to achieve optimal oil temperature control. A perfect complement to our remote oil cooler kits. Attached thumbnail(s) ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 13th July 2025 - 10:34 AM |
