> OT: Chrysler Sebring convertible hardtop Limited 3.5 L, 2008, Looking to find And fix a electrical issue
Garland
post Aug 29 2020, 09:40 AM
Restoration Fanatic
This is my sons car, and here’s the description of the concerns. This is an intermittent concern, and unable to duplicate in a shop environment so far.
Sebring issues
Radio restarts - sometimes when restarting the car, the head unit forgets where it’s place was on the CD and restarts from track 1. Very rarely, the radio controls on the steering wheel will go inoperable and after a few minutes the head unit will reboot.
Fuel pump dies - occasionally when trying to start the vehicle, the fuel pump does not prime, as if it is not getting power. This is almost always resolved by hooking up a jump box to the jump points under the hood. Because of the intermittent fuel pump issues, the back seat is not latched down and can be easily removed.
Vehicle dies - occasionally when driving at various speeds, when stopped, or when putting the vehicle into reverse, the vehicle will bog down and die as if the vehicle is out of fuel. Usually this is followed by the fuel pump not priming and needing to either jump the vehicle or let it rest for several minutes before restarting.
Security light comes on - sometimes while driving or stopped, and rarely while parked, the security light on the speedometer will illuminate. About a second later, the low tire pressure light will also illuminate. After a few moments, the tire light will turn off and then the security light will turn off.
Once the alarm went off as I was turning off/exiting the vehicle. I was unable to turn the alarm off except by re-starting the vehicle and pushing the PANIC button on the key while the vehicle was running.
Once when I took the key out of the ignition, the vehicle thought the key was still in the ignition. The ignition switch is original to the vehicle.
We replaced the fuel pump, spark plugs, battery, and cleaned all battery terminals.
Horn gets stuck - believe to be a stuck horn pad, which I have a replacement.
Any thoughts or help would be appreciated.
- Lo-Fi Version Time is now: 18th March 2026 - 07:19 PM
