Any D Jet experts in Seattle? |
Robson51 |
Sep 5 2020, 12:00 PM
Member Group: Members Posts: 88 Joined: 18-November 19 From: seattle Member No.: 23,654 Region Association: Pacific Northwest |
Looking for some help from an in person human being before going to Webers.
Anyone out in Seattle (actually just north) that wants to make some side money? TIA |
914werke |
Sep 14 2020, 03:22 PM
"I got blisters on me fingers" Group: Members Posts: 9,999 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Rechecked the MPS with a better vacuum gauge. It will not hold vacuum, so is being sent out for repair. A bad MPS will do it. (IMG:style_emoticons/default/headbang.gif) |
Rand |
Sep 14 2020, 03:44 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Rechecked the MPS with a better vacuum gauge. It will not hold vacuum, so is being sent out for repair. A bad MPS will do it. (IMG:style_emoticons/default/headbang.gif) THIS is why i asked you to pull the hose from the MPS and report the difference. (IMG:style_emoticons/default/headbang.gif) Some clues point to obvious and when it only takes SECONDS to test.... |
Robson51 |
Sep 15 2020, 03:43 PM
Rechecked the MPS with a better vacuum gauge. It will not hold vacuum, so is being sent out for repair. A bad MPS will do it. (IMG:style_emoticons/default/headbang.gif) THIS is why i asked you to pull the hose from the MPS and report the difference. (IMG:style_emoticons/default/headbang.gif) Some clues point to obvious and when it only takes SECONDS to test.... Actually, it died when I did that. The leakdown takes a good minute to go to zero. |
Rand |
Sep 15 2020, 07:11 PM
Actually, it died when I did that. The leakdown takes a good minute to go to zero. Sorry about that, I took it too literal when you said it won't hold a vacuum. Holding for a minute isn't as bad as it sounded, and since it died when you pulled the hose it also shows it was holding some vacuum. Sounds like there's more going on than just the MPS diaphragm. Good luck, you're in good hands. |
Lo-Fi Version | Time is now: 25th April 2024 - 04:30 AM |
