| carl k |
Sep 7 2020, 03:37 PM
Member ![]() ![]() Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None
This complete GC code 2.0 Liter Porsche 914 engine was removed from my 1975 after I lost the #3 cylinder. I have not investigated the cause. It comes with everything you'd need to install, including all of the cooling tins, shrouds, good working alternator, Spanish Weber 44 IDF carbs/linkage, Compufire electronic ignition, no pulled exhaust studs, working bellows thermostat with all cooling flaps intact, engine mount set up for side shift, hydraulic cam (grind is unknown) so fewer valve adjustments, no major leaks/clean. Engine sounded good when running and no "bang", so maybe just a burnt valve. SOLD
Thanks, Carl |
| carl k |
Sep 7 2020, 04:18 PM
| carl k |
Sep 12 2020, 06:34 PM
engine number
Lo-Fi Version | Time is now: 9th April 2026 - 12:20 PM |
