brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,016 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
an original, J-tube cap for the heater system
not cracked, clean condition $6 shipped in the US Attached thumbnail(s) ![]() ![]() ![]() |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,098 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
I just bought three of those. (IMG:style_emoticons/default/biggrin.gif)
brant |
Nice.
does the -6 use them? |
BillC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 678 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
I'll take it! PM incoming.
nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,262 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
Can you get me the inside and outside diameter? Wondering if this will fit the backdated heat pipe off the fan shroud (drivers side)
Gint |
They fit over the J tube that comes up through the engine tin from the heat ex changers. If you don't have a auxiliary electric fan, you use these to cap off the J tubes. So whatever size that J tube is, the inside diameter of the cap needs to fit over, and not necessarily snugly. They are typically fitted with a hose clamp, which is why they have two slots. Getting an accurate inner and outer dimension on a 50 year old plastic cap is a bit of a crap shoot, but...
2.13" inner (54.2 mm) 2.37" outer (60.3 mm) |
Lo-Fi Version | Time is now: 18th July 2025 - 07:06 PM |
