help with removing front shock top nut (Koni) |
Stltri |
Sep 15 2020, 04:28 PM
Member Group: Members Posts: 70 Joined: 13-April 15 From: SoCal Member No.: 18,622 Region Association: None |
Been trying to track down a clunk from the driver front end. Car is a 74 with Koni adjustable insert/shocks on all 4 corners. Looks like its coming from the shock on driver side at the top. Something is loose inside the shock tube and/or cover which duplicates what I hear/feel while driving. I checked everything else on the arms/rack/torsion bars/ball joint and everything tight (since I just also recently replaced all bushings etc). So I wanted to remove the shock to take a look but could not remove the nut after loosening it (while countering with a pipe wrench). I suspect the tab washer (which usually locks the nut and prevent it from spinning) broke. I have read that maybe a impact wrench (I have a cordless and corded impact but not air impact wrench) may spin it loose but may also damage the shock internals so I have not tried that route? Any other ideas on how to remove the nut?
mepstein |
Sep 15 2020, 05:24 PM
914-6 GT in waiting Group: Members Posts: 19,220 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I use an impact wrench to remove. Takes two seconds and no shock damage. I was told to do it that way by a long time Porsche tech.
It’s not on super tight so any cordless should work fine. Clunks are usually from the large strut top nut under the large dust cap/metal cylinder coming loose. A pipe wrench will tighten it down. |
Stltri |
Sep 15 2020, 06:23 PM
I use an impact wrench to remove. Takes two seconds and no shock damage. I was told to do it that way by a long time Porsche tech. It’s not on super tight so any cordless should work fine. Clunks are usually from the large strut top nut under the large dust cap/metal cylinder coming loose. A pipe wrench will tighten it down. I will try the impact wrench shortly but here's a quick video of what I was describing. The dished washer is actually stationary and the threaded rod of shock and nut are turning together. IMG_4943.MOV ( 958.25k ) Number of downloads: 100 |
Lo-Fi Version | Time is now: 18th April 2024 - 11:11 PM |
