help with removing front shock top nut (Koni) |
Stltri |
Sep 15 2020, 04:28 PM
Member Group: Members Posts: 70 Joined: 13-April 15 From: SoCal Member No.: 18,622 Region Association: None |
Been trying to track down a clunk from the driver front end. Car is a 74 with Koni adjustable insert/shocks on all 4 corners. Looks like its coming from the shock on driver side at the top. Something is loose inside the shock tube and/or cover which duplicates what I hear/feel while driving. I checked everything else on the arms/rack/torsion bars/ball joint and everything tight (since I just also recently replaced all bushings etc). So I wanted to remove the shock to take a look but could not remove the nut after loosening it (while countering with a pipe wrench). I suspect the tab washer (which usually locks the nut and prevent it from spinning) broke. I have read that maybe a impact wrench (I have a cordless and corded impact but not air impact wrench) may spin it loose but may also damage the shock internals so I have not tried that route? Any other ideas on how to remove the nut?
mepstein |
Sep 17 2020, 03:18 PM
914-6 GT in waiting Group: Members Posts: 19,239 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
There’s a 2-3mm gap with bilstein inserts so the gap you have might be normal. I checked with Bilstein tech dept and they said they get asked all the time but it’s designed to have a gap rather than bottom out and still be a little loose. I did t know about other brands but they might be similar design.
Stltri |
Sep 17 2020, 05:42 PM
There’s a 2-3mm gap with bilstein inserts so the gap you have might be normal. I checked with Bilstein tech dept and they said they get asked all the time but it’s designed to have a gap rather than bottom out and still be a little loose. I did t know about other brands but they might be similar design. That makes sense. Thanks for everyone's help. Hopefully reassembly will be smoother. Now waiting for replacement hardware from Koni (tab washer, dished washer, nut). Thanks to Mason of Koni-NA. Actually found a thread similar to my problems, not sure why I didn't find it earlier. @krieger had a great idea of cutting the cover by 1 1/2" to expose the gland nut when car is lifted but covers it when down on the ground. This allows quick inspection and tightening of the gland nut if needed. Anybody else done this? http://www.914world.com/bbs2/index.php?showtopic=288552 |
Lo-Fi Version | Time is now: 25th April 2024 - 06:48 PM |
