Targa Vinyl adhesive recommendations |
draganc |
Sep 15 2020, 08:42 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hi folks!
I’m looking for targa vinyl adhesive recommendations and what products to stay away, I read Eric’s installation summary (thanks a bunch!!) but besides 3M didn’t find any specific p/n for 3M or other good adhesives. Who has used what and with what kind of experience? Car is fresh painted (about 3 months old) and I really don’t want to fudged it up with some “budget/mainstream” FLAPS stuff. Thanks in advance! dc |
draganc |
Sep 16 2020, 08:49 AM
Interesting approach about the double sided tape!
Do you have a p/n or description of it? I don’t know if it’s my phone, but your picture looks like that there are “lines” showing. In what pattern did you apply the tape for in between the edges? Cheers! |
wysri9 |
Sep 17 2020, 12:26 AM
Member Group: Members Posts: 199 Joined: 23-August 13 From: Aberdeen, Scotland Member No.: 16,291 Region Association: England |
Interesting approach about the double sided tape! Do you have a p/n or description of it? I don’t know if it’s my phone, but your picture looks like that there are “lines” showing. In what pattern did you apply the tape for in between the edges? Cheers! i used 3M 9088 Double Sided High Performance Clear Tape. Its 0.1mm thick and so invisible. I DID NOT use VMB foam tape which is incredibly sticky but also 1mm thick. I put tape around the perimeter of the panel initially and then "wrapped" the edges onto tape there. The vinyl stretched slightly as I formed it over the panel and stayed in position well once onto the tape. I guess you could add more rows of tape but my upholsterer friend suggested what I did. Time will tell..... (IMG:style_emoticons/default/smile.gif) |
mepstein |
Sep 17 2020, 06:07 AM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Interesting approach about the double sided tape! Do you have a p/n or description of it? I don’t know if it’s my phone, but your picture looks like that there are “lines” showing. In what pattern did you apply the tape for in between the edges? Cheers! i used 3M 9088 Double Sided High Performance Clear Tape. Its 0.1mm thick and so invisible. I DID NOT use VMB foam tape which is incredibly sticky but also 1mm thick. I put tape around the perimeter of the panel initially and then "wrapped" the edges onto tape there. The vinyl stretched slightly as I formed it over the panel and stayed in position well once onto the tape. I guess you could add more rows of tape but my upholsterer friend suggested what I did. Time will tell..... (IMG:style_emoticons/default/smile.gif) wysri9. Thanks for the info. Sounds like the tape might be a great alternative to the spray. |
Lo-Fi Version | Time is now: 28th March 2024 - 04:01 PM |
