Lay down sally |
Lay down sally |
troth |
Sep 17 2020, 01:33 PM
Member Group: Members Posts: 151 Joined: 17-August 16 From: CT/WA Member No.: 20,305 Region Association: None |
Think I’m going to have to cross mine off the VIN registry.
Fuck, I love this car. Corrosion already starting everywhere the water made it up to. Going to hose it down with fresh water and spray some WD-40 wherever I can. Looking for any tips on how to preserve as much as possible. |
djway |
Sep 19 2020, 03:51 AM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
Open up everything, remove anything that holds moisture.
Home Depot sells straight Phosphoric Acid, dilute to around 20% and spray like crazy, use a mask. It leaves a white zinc phosphate powder that can keep bare metal rust free for years, especially if you don't wipe it down. Blow air through closed cavities to dry the spray in some phosphoric and also you can use Eastwood internal frame coating. Just drown any closed chamber. Fluid film can be used on a lot of the parts or surfaces. You can also use some epoxy paint after the acid if you clean it with a non aqueous pre paint cleaner. These are just a few products available. Many electronic items can be opened and cleaned. Never surrender |
Lo-Fi Version | Time is now: 12th May 2024 - 02:29 PM |
