Master Cylinder Installation, 2 Quick Questions |
Craigers17 |
Sep 18 2020, 03:22 PM
Senior Member Group: Members Posts: 733 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
So I'm in the processing of re-installing my master cylinder, brakes etc. I had to take the 90 degree fitting off of the old master cylinder & use on the new one. My questions are:
1. Is there a washer or gasket that goes between the main M/C body and the fitting or just a washer between the 2 parts of the fitting? 2. There is a hole for the fluid to flow through in both the fitting body and the piece that pivots around it, for each of the front brakes. My question is do these 2 holes have to line up? My guess is they don't, but just wanted to double check before I install this beast....I really don't want to do this twice. I hope I have explained this accurately,...I'm just referring to the front brake splitter for lack of a better term, ...not the feed lines to the reservoir. I do realize that I need a washer below the rubber grommets where the feed lines go. Thanks for your help. |
bdstone914 |
Sep 19 2020, 07:30 AM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Yes you need a crush washer on both sides of the vanjo fitting. The washers are different sizes. One size is NLA from Porsche. I found a replacement in a Wurth selection of crush washers. You can reuse the old ones. If they are copper flatten them in a vise then aneal them by heating to red hot and drop them in water. That softens the metal for a better seal.
No need to align the hole. I later bought a bag of 50 crush washers from McMaster carr. |
ri914 |
Sep 19 2020, 08:06 AM
Member Group: Members Posts: 102 Joined: 13-August 20 From: rhode island Member No.: 24,593 Region Association: North East States |
Yes you need a crush washer on both sides of the vanjo fitting. The washers are different sizes. One size is NLA from Porsche. I found a replacement in a Wurth selection of crush washers. You can reuse the old ones. If they are copper flatten them in a vise then aneal them by heating to red hot and drop them in water. That softens the metal for a better seal. No need to align the hole. I later bought a bag of 50 crush washers from McMaster carr. haha I called it a banjo fitting (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 03:48 PM |
