Master Cylinder Installation, 2 Quick Questions |
Craigers17 |
Sep 18 2020, 03:22 PM
Senior Member Group: Members Posts: 733 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
So I'm in the processing of re-installing my master cylinder, brakes etc. I had to take the 90 degree fitting off of the old master cylinder & use on the new one. My questions are:
1. Is there a washer or gasket that goes between the main M/C body and the fitting or just a washer between the 2 parts of the fitting? 2. There is a hole for the fluid to flow through in both the fitting body and the piece that pivots around it, for each of the front brakes. My question is do these 2 holes have to line up? My guess is they don't, but just wanted to double check before I install this beast....I really don't want to do this twice. I hope I have explained this accurately,...I'm just referring to the front brake splitter for lack of a better term, ...not the feed lines to the reservoir. I do realize that I need a washer below the rubber grommets where the feed lines go. Thanks for your help. |
IronHillRestorations |
Sep 19 2020, 07:00 PM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Yes you need a copper sealing ring on both sides of the banjo fitting, no crush washers (they’re for the drain plug).
These are sealing rings, they’re solid copper (or aluminum for other applications), and what you need for sealing higher pressure banjo fittings, and do not or should not noticeably deform. These are crush washers and are for things like the oil drain plug, or oil sump nut. They are designed to compress to aid sealing, but should not be used for brake fittings |
bdstone914 |
Sep 20 2020, 08:14 AM
bdstone914 Group: Members Posts: 4,521 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@IronHillRestorations
date='Sep 19 2020, 06:00 PM' post='2852581'] Yes you need a copper sealing ring on both sides of the banjo fitting, no crush washers (they’re for the drain plug). These are sealing rings, they’re solid copper (or aluminum for other applications), and what you need for sealing higher pressure banjo fittings, and do not or should not noticeably deform. These are crush washers and are for things like the oil drain plug, or oil sump nut. They are designed to compress to aid sealing, but should not be used for brake fittings [/quote] Perry, Thanks for the correction. I miss spoke when i call them crush washers. Do you prefer copper or aluminum sealing washers? My thought is that aluminum is softer but can cause corrosion when against a steel surface. I like to aneal the copper washers to soften them. |
Lo-Fi Version | Time is now: 16th May 2024 - 12:40 AM |
