Great custom Exhaust deal, Stainless setup for cheap |
ri914 |
Sep 20 2020, 08:23 AM
Member Group: Members Posts: 102 Joined: 13-August 20 From: rhode island Member No.: 24,593 Region Association: North East States |
While gathering parts for the LS6 swap I used Amazon and eBay to get some exhaust supplies. It amazes me what 240$ was able to collect.
Amazon had a full stainless mandrel bent kit for around 150 delivered. Enough to do 3 or 4 cars. A pair of coated stainless mufflers for 42$ and an x pipe for 22.50? I swear the last time I bought a mandrel bent pipe it was probably 40$ for 1 piece? Anyway just thought I would share this info. A lot of people need help with exhausts. This seems like a great deal. ( beware, some sell the same kit for over 500$ ) actual current add my kit with mufflers and x pipe |
Andyrew |
Sep 20 2020, 10:02 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
I'm surprised how few people go stainless over standard aluminized steel.
I went with stainless 3" exhaust for my 1.8t conversion. 3" and probably only increased my cost by 50%. Two 3" mandrel bent J pipes ($45)and two 3" stainless resonators($40) and that was it. Spent $35 for a small spool of stainless wire and it was enough to do the exhaust and all my coolant pipes and intercooler joiners which was also stainless. It welds almost exactly like standard mig wire. |
mepstein |
Sep 20 2020, 10:06 AM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
There are different grades of stainless. We had some cheap 911 headers at the shop and they weren't rusty but almost. Ben could probably write pages on the subject.
@MB911 |
Mueller |
Sep 20 2020, 11:06 AM
I'm surprised how few people go stainless over standard aluminized steel. I went with stainless 3" exhaust for my 1.8t conversion. 3" and probably only increased my cost by 50%. Two 3" mandrel bent J pipes ($45)and two 3" stainless resonators($40) and that was it. Spent $35 for a small spool of stainless wire and it was enough to do the exhaust and all my coolant pipes and intercooler joiners which was also stainless. It welds almost exactly like standard mig wire. Do you have to back fill when MIG welding it? |
Superhawk996 |
Sep 20 2020, 11:23 AM
914 Guru Group: Members Posts: 5,778 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Just a side note looking at the picture. Those "mufflers" aren't going to do squat for a LS in terms of noise. You're typically looking for 5-10 times the engine displacment for an effective muffler that will flow sufficient volume and still offer opportunity for baffling and noise suppression.
Personally, those look to me like resonators that would be used to "tune" a system for tone. I'll leave final word to Ben on back purge but in my opinion it is best practice for stainless. If you don't you'll get oxide and "sugaring" on the backside of the weld heat affected zone that will eventually compromise it. I'd bet there are exceptions but if you're going to do the work, why risk it? |
Superhawk996 |
Sep 20 2020, 11:28 AM
delete - duplicate post by accident
Mark Henry |
Sep 20 2020, 03:21 PM
It's likely 409 stainless, which is OK, better than plain steel, but it will rust sort of like a like a brown patina. once sorted I'd recommend getting it ceramic coated. Look for the welded seam, you want to try to face it upwards. Easy to tell 409 from 304 as the 409 is magnetic.
304 is the preferred, it turns a bit blue but it stays shiny. Non-magnetic, but areas near bends an welds become magnetic, always check on straight or flat areas. |
mb911 |
Sep 20 2020, 04:41 PM
914 Guru Group: Members Posts: 6,823 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I could provide a kit like that but would likely cost twice but it would be 304 and made here.
Mikey914 |
Sep 20 2020, 04:58 PM
The rubber man Group: Members Posts: 12,652 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
304 will brown, 316 is best if you want a show exhaust.
The materials are relatively cheap. The value is in a bolt on solution. |
ri914 |
Sep 20 2020, 08:03 PM
I will test the pipes with a magnet tomorrow. I think the description said 304.
Any suggestions on a good muffler? I appreciate all the comments. I went with stainless because every exhaust I built without it had problems. I figure I will most likely build a few systems before I land on something suitable. Can anyone reccomend a good heat reflection tape for the hydraulic lines and shifter cables? |
Mark Henry |
Sep 21 2020, 07:11 AM
Can anyone reccomend a good heat reflection tape for the hydraulic lines and shifter cables? Aeroquip Fire sleeve. (IMG:http://www.914world.com/bbs2/uploads/post-26-1497650959_thumb.jpg) |
Superhawk996 |
Sep 21 2020, 07:27 AM
@Mark Henry Really like that routing tube for the cables. Great Job! I'll copy that with pride someday! |
jd74914 |
Sep 21 2020, 07:34 AM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I'll leave final word to Ben on back purge but in my opinion it is best practice for stainless. If you don't you'll get oxide and "sugaring" on the backside of the weld heat affected zone that will eventually compromise it. I'd bet there are exceptions but if you're going to do the work, why risk it? In my experience the back purge is makes the welding a bit nicer in areas where is it tough to fully clean grease (or wax) from the mill/forming process. If you were welding by B31.1/3 (power/process piping) you'd be forced to purge when welding SS tube/pipe. Good rule to follow for hobby stuff since regulators are so cheap and it doesn't take much gas. (IMG:style_emoticons/default/smile.gif) |
Andyrew |
Sep 21 2020, 08:25 AM
I'm surprised how few people go stainless over standard aluminized steel. I went with stainless 3" exhaust for my 1.8t conversion. 3" and probably only increased my cost by 50%. Two 3" mandrel bent J pipes ($45)and two 3" stainless resonators($40) and that was it. Spent $35 for a small spool of stainless wire and it was enough to do the exhaust and all my coolant pipes and intercooler joiners which was also stainless. It welds almost exactly like standard mig wire. Do you have to back fill when MIG welding it? Mike, I contemplated it but did not. The insides of the welds look nice and they have certainly got a lot of heat already. No issues. Side note, I've also welded up some cracked factory welds from a Magnaflow exhaust on my Infiniti. Its been a year and 30k miles with no further leaks. No back purging. Would I do this to a turbo header? No.... but I dont see any reason not to do it to exhaust. I'll take a pic of the exhaust on the 914 later. |
Lo-Fi Version | Time is now: 5th May 2024 - 05:28 AM |
