Great custom Exhaust deal, Stainless setup for cheap |
ri914 |
Sep 20 2020, 08:23 AM
Member Group: Members Posts: 102 Joined: 13-August 20 From: rhode island Member No.: 24,593 Region Association: North East States |
While gathering parts for the LS6 swap I used Amazon and eBay to get some exhaust supplies. It amazes me what 240$ was able to collect.
Amazon had a full stainless mandrel bent kit for around 150 delivered. Enough to do 3 or 4 cars. A pair of coated stainless mufflers for 42$ and an x pipe for 22.50? I swear the last time I bought a mandrel bent pipe it was probably 40$ for 1 piece? Anyway just thought I would share this info. A lot of people need help with exhausts. This seems like a great deal. ( beware, some sell the same kit for over 500$ ) actual current add my kit with mufflers and x pipe |
Superhawk996 |
Sep 20 2020, 11:23 AM
914 Guru Group: Members Posts: 5,857 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Just a side note looking at the picture. Those "mufflers" aren't going to do squat for a LS in terms of noise. You're typically looking for 5-10 times the engine displacment for an effective muffler that will flow sufficient volume and still offer opportunity for baffling and noise suppression.
Personally, those look to me like resonators that would be used to "tune" a system for tone. I'll leave final word to Ben on back purge but in my opinion it is best practice for stainless. If you don't you'll get oxide and "sugaring" on the backside of the weld heat affected zone that will eventually compromise it. I'd bet there are exceptions but if you're going to do the work, why risk it? |
jd74914 |
Sep 21 2020, 07:34 AM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I'll leave final word to Ben on back purge but in my opinion it is best practice for stainless. If you don't you'll get oxide and "sugaring" on the backside of the weld heat affected zone that will eventually compromise it. I'd bet there are exceptions but if you're going to do the work, why risk it? In my experience the back purge is makes the welding a bit nicer in areas where is it tough to fully clean grease (or wax) from the mill/forming process. If you were welding by B31.1/3 (power/process piping) you'd be forced to purge when welding SS tube/pipe. Good rule to follow for hobby stuff since regulators are so cheap and it doesn't take much gas. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 26th May 2024 - 12:23 AM |
