Proper Torsion bar install and adjustment, how to install and adjust the torsion bars on the front suspension |
ri914 |
Sep 20 2020, 10:00 AM
Member Group: Members Posts: 102 Joined: 13-August 20 From: rhode island Member No.: 24,593 Region Association: North East States |
Hello 914'ers
I need to adjust and calibrate my front suspension. I installed the new torsion bars while the car was on the lift and it now looks like it could chase a ford raptor through the woods. 1: Is there a procedure for installing these and what angle the a-arm should be at? 2: Should they be done at ride height and then adjusted by the torsion bar adjustment bolt ? thank you ben |
mlindner |
Sep 20 2020, 01:52 PM
Senior Member Group: Members Posts: 1,522 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Ri914, your pictures shows how far off it is. With car weight on suspension that front A-arm should be horizontal as a good start point. If you have purchased stiffer bars you might need to index them on the lift raising the front suspension with like a transmission jack before torsion bar is set. Mark
ri914 |
Sep 20 2020, 08:45 PM
Ri914, your pictures shows how far off it is. With car weight on suspension that front A-arm should be horizontal as a good start point. If you have purchased stiffer bars you might need to index them on the lift raising the front suspension with like a transmission jack before torsion bar is set. Mark Great info everyone! Mark. Thanks for the explanation. I knew they had to be way off. Fingers crossed I don't have to roll the fenders. |
Lo-Fi Version | Time is now: 21st May 2024 - 08:40 PM |
