DOOR HANDLES, Replacement |
struckn |
Sep 20 2020, 06:35 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
My '74 914's driver side door handle broke a couple months ago. It cracked in two and I tried JB Weld to get it back together. Seemed to work great until last week when it broke again where I had the JB Weld covering the cracked area and over lapped the pot metal beyond the crack.
So I'm waiting for an after market replacement I ordered from Pelican. Their cost was less then half of an original Porsche replacement Handle's cost. Pelican described the original 914 Handles as one of the major problem areas to fail. We'll see how it goes, the reviews from others say it works, fits and looks the same. I had taken out the original Handle once before. It's not a hard fix. Only concern is how to remove the original Key mechanism from the original handle and install it in the after market Handle. I'll figure it out, can't be too difficult. Oh, when I ordered the replacement Pelican shows it to be the last one that had. Tally Hoe! Doug in New Freedom Pa. |
914Sixer |
Sep 21 2020, 06:09 AM
914 Guru Group: Members Posts: 8,883 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Put the key in the lock and take the screw of the back. Gently pull up on tab, there is a spring under it. Spring may try to fly. Clean up lock and lube. Reverse assembly.
Poor chrome and lock not fitting barrel has been my past experience. |
struckn |
Sep 21 2020, 09:23 AM
Put the key in the lock and take the screw of the back. Gently pull up on tab, there is a spring under it. Spring may try to fly. Clean up lock and lube. Reverse assembly. Poor chrome and lock not fitting barrel has been my past experience. Thanks Good to know. I believe the Spring and possibly other small parts are not coming with the replacement after market new handle so I need to check these things once I'm set to remove and install the new replacement handle. Doug |
Lo-Fi Version | Time is now: 19th May 2024 - 08:17 AM |
