911/914-6 2.4 S spec engine for sale turn key. |
mb911 |
Sep 21 2020, 08:13 AM
914 Guru Group: Members Posts: 6,810 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I am offering up my fresh run on test stand and test fired in my car only 2.4 S spec engine. Includes the following
2.2 S pistons thermally coated 2.4 cast iron cylinders nikisal plated(Supertec handled it) Flow improved oil pump Reconditioned rods with ARP bolts Fresh ground crank .010 under Case machined .010 under as well both by supertec Heads were ported and polished by supertec Carrera tensioners Steel studs with case savers 123 dizzy Every nut and bolt has been plated Carbs are idts with correct venturies and jetting for the solex cams New throttle linkage cross bar, air filter assemblies, rebuilt alternator, Includes on engine oil filter which replaces oil cooler. 1.5-1.625 stepped headers Cleaned and cerakoted side shift trans with throttle linkage conversion 914-6 engine sheet metal. 914-6 sport muffler No engine mount or oil lines included as they will stay with my car. $19,000 obo and will split trans and consider core engines as partial trades.. I am only selling out of necessity as I really don't want to be engineless but you know how it goes. You can come hear it run prior to removal. This will be an as is sale as I can't be responsible for someone installing incorrectly or changing timing or forgetting to add oil etc.. This is very nice engine and documentation exist on the build here on the forum. I will post a picture of it on the stand. Please note the steel air filter is not included.. |
mb911 |
Sep 21 2020, 09:32 AM
Lo-Fi Version | Time is now: 24th April 2024 - 10:34 PM |
