Voltage drop |
Voltage drop |
Dave97 |
Sep 22 2020, 05:41 PM
Newbie Group: Members Posts: 42 Joined: 25-July 17 From: Calif Member No.: 21,285 Region Association: None |
What is normal voltage drop when you turn on the lights? I’m just going off the volt meter, but I start at about 14.2 driving around, when I pull on even the first notch of the light switch I’ll drop to less than 13. Is it a ground issue? I understand that this a rather common. Thanks. Dave
ClayPerrine |
Sep 22 2020, 06:45 PM
Life's been good to me so far..... Group: Admin Posts: 15,447 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Ignore it. The voltmeter in the console of a 914 is about as accurate as a shotgun loaded with gravel. Use it as a general guide, not a precise instrument. If it starts trending downward, then worry.
Lo-Fi Version | Time is now: 11th May 2024 - 03:24 PM |
