Voltage drop |
Voltage drop |
Dave97 |
Sep 22 2020, 05:41 PM
Newbie Group: Members Posts: 42 Joined: 25-July 17 From: Calif Member No.: 21,285 Region Association: None |
What is normal voltage drop when you turn on the lights? I’m just going off the volt meter, but I start at about 14.2 driving around, when I pull on even the first notch of the light switch I’ll drop to less than 13. Is it a ground issue? I understand that this a rather common. Thanks. Dave
GregAmy |
Sep 22 2020, 06:46 PM
Advanced Member Group: Members Posts: 2,291 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I took mine out, I hated it so much. The light on the dash gives you what you need to know. Edit: and then, when you have big feet like me and you accidentally knock out the fuse, but don't notice the dead voltmeter until you're well away from home at night in the rain, and you panic and get all wet only to figure out it was just the fuse...out you go. |
Lo-Fi Version | Time is now: 11th May 2024 - 12:26 PM |
