Voltage drop |
Voltage drop |
Dave97 |
Sep 22 2020, 05:41 PM
Newbie Group: Members Posts: 42 Joined: 25-July 17 From: Calif Member No.: 21,285 Region Association: None |
What is normal voltage drop when you turn on the lights? I’m just going off the volt meter, but I start at about 14.2 driving around, when I pull on even the first notch of the light switch I’ll drop to less than 13. Is it a ground issue? I understand that this a rather common. Thanks. Dave
porschetub |
Sep 22 2020, 09:20 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Don't trust mine but its sort of an indicator,but being wired off the centre console wiring and dash mounted most likely causing a false reading of 1V low which I have,another job on the list (IMG:style_emoticons/default/dry.gif) .
Lo-Fi Version | Time is now: 11th May 2024 - 01:10 PM |
