Fuel pump issue, no fuel... help |
steuspeed |
Sep 22 2020, 09:43 PM
Senior Member Group: Members Posts: 1,006 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
What am I missing? Turn the key and I can hear the fuel pump run then stop. Turn key to start and the engine cranks. Broke the lines in the engine bay. Crank the engine and no fuel comes out the hoses. Blocked line between pump and engine bay?
If I spray some start fluid in the air box the engine fires right up. This is my new project car. Just drove it home last week. |
Frankvw |
Sep 23 2020, 01:07 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
No fuel at all ...mmm...after pump : maybe clogged up fuelfilter. Could also be fuelpump itself ofcourse.
If there is no fuel on the pumpside (before pumpaction) maybe kinked fuel hose under the tank or the filter in the tank is clogged) |
steuspeed |
Sep 23 2020, 02:15 AM
No fuel at all ...mmm...after pump : maybe clogged up fuelfilter. Could also be fuelpump itself ofcourse. If there is no fuel on the pumpside (before pumpaction) maybe kinked fuel hose under the tank or the filter in the tank is clogged) There is an old filter down by the fuel pump. That is my next move. Does the pump run until it gets pressure? I'm thinking if it's clogged then the pump runs and stops for that. |
Lo-Fi Version | Time is now: 14th May 2024 - 11:58 PM |
