welp this happened, think mcfly think |
bludden |
Sep 23 2020, 01:22 PM
Member Group: Members Posts: 57 Joined: 15-June 20 From: Charlotte NC Member No.: 24,380 Region Association: South East States |
I didn't engage the parking brake hard enough and it rolled into a tree. At first my trunk lock was stuck but using the rubber mallet treatment it came loose - its got spring tension but nothing is releasing. I can't get the trunk to open. Most of my good tools as well as my targa top is in there. Any suggestions? I was thinking i could take the bolts off the front of the trunk and get in there but that seems to be a pretty bad option.
bretth |
Sep 23 2020, 01:34 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Ugh. So sorry to see this. I hear that others go in through the engine compartment and push the plastic cups out where the targa sits in the trunk. Then use many socket extensions to reach and loosen the truck latch bolts. Not sure how doable this is with the top in the trunk though. Hopefully others will chime in.
ndfrigi |
Sep 23 2020, 02:28 PM
Oh No! sorry for what happened to your car. About opening the rear trunk, if the passenger side lens is not repairable, probably you can just cut it or something that you can use your arm to go in there and reach the latch.
If you want to access from the engine on the plastic cups like mentioned above, that will be better except if you have lots of items there that is blocking to access to the latch. |
bludden |
Sep 23 2020, 02:34 PM
yeah the tail light seems to be the best bet, it will need to be replaced anyways. Im scheduled to go to TN tomorrow but if the trunk is really broken and half the tail lights are out, not sure how I'm going to do it...
ndfrigi |
Sep 23 2020, 02:40 PM
yeah the tail light seems to be the best bet, it will need to be replaced anyways. Im scheduled to go to TN tomorrow but if the trunk is really broken and half the tail lights are out, not sure how I'm going to do it... damaged is repairable and I’m sure if you need replacement rear trunk, someone from our members can help. |
nditiz1 |
Sep 23 2020, 02:52 PM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
When I accidentally put my trunk lock on upside down (IMG:style_emoticons/default/headbang.gif) I was locked out. I unbolted the hinges and was able to lift the trunk enough to get to the bolts holding the latch (10mm). My top was in the trunk as well. I dont have the springs on though so I'm not sure how that will factor in.
Cairo94507 |
Sep 23 2020, 04:20 PM
Michael Group: Members Posts: 9,711 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
bludden |
Sep 23 2020, 05:38 PM
Well I managed to get it open. Tore off the already broken lens, some of the tail light mount was already broken so I took some more off to clear the bottom and top, managed to get the tail light plastic that has the screw mounts to the point where I could screw them off, removed 2 screws for the reflective piece to remove it and pop the bulb mounts out, then cut off the inside wall of the mount and out to the mounting post so I could reach behind and undo the first 2 nuts, then another cut out in the middle of the piece to get to the other 2 bolts. Then I was able to reach into the trunk and remove the 2 bolts for the lid lock. Tomorrow I will see what I can do about getting everything back together so everyone in TN can laugh at my misfortune. If I do go I will have the lights together, but the passenger side lens is toast. If anyone has an extra to sell please let me know, it can be ugly if it works as I'll be replacing the entire assembly when the car is fixed.
windforfun |
Sep 23 2020, 06:11 PM
Senior Member Group: Members Posts: 1,775 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
You're in my prayers. Take it slow. This can be fully restored to as good as new.
poorsche914 |
Sep 23 2020, 07:08 PM
T4 Supercharged Group: Members Posts: 3,087 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
I found a taillight housing that is in kinda rough shape but you are welcome to it if nothing better comes your way. No luck on a lens, however.
I will bring it to Teenerpalüza. steve (IMG:style_emoticons/default/driving.gif) |
FlacaProductions |
Sep 23 2020, 07:37 PM
Senior Member Group: Members Posts: 1,554 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Tangentially related and I hope it's not a hijack - but do most of you engage a gear in addition to setting the parking brake?
edit - and my bad for not including this originally @bludden but i'm sorry about this incident and it really sucks. |
RRietman |
Sep 23 2020, 07:43 PM
Member Group: Members Posts: 99 Joined: 13-December 09 From: Pacific Northwest USA Member No.: 11,124 Region Association: None |
bludden |
Sep 23 2020, 08:13 PM
Tangentially related and I hope it's not a hijack - but do most of you engage a gear in addition to setting the parking brake? edit - and my bad for not including this originally @bludden but i'm sorry about this incident and it really sucks. I always put it into first. Except this time. I had a bunch of stuff to carry into the house and it just slipped my mind. Also theres a dumpster we we rented for the week that they put at the top of the driveway this morning where it's almost flat so I was on more of an incline than the car is on usually. I have full coverage on the car from the same company as my homeowners, wonder if any of this would be covered? I've never had an insurance claim in my life lol |
Tdskip |
Sep 23 2020, 09:19 PM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
First of all – sorry to see this, I bet that had to be stomach churning.
Policies and coverage vary, but if this were Hagerty they would simply bring it to an agreed to shop, their person would come over write up the damage amount, and then they would pay to get it fixed. It shouldn’t come anywhere close to totaling the car, so I am inclined to think that you’re covered. Use it – my guess is that a professional shop would not try to hammer that out but instead pull it and they should be able to check dimensions in the process . I might want to start checking around to see if there are 914 experience shops in the area. Hang in there – as the others have suggested that is eminently repairable. |
Mikey914 |
Sep 24 2020, 12:03 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
That sucks.
You may be luck enough that you can locate a rear deck lid to repaint and I'm thinking it may be possible to pull out the damage. A pic of the inside trunk at the seam would let you know, but it's possible from the way the cross support goes that it could be pulled. From what I can see it should be able to be repaired at any reputable body shop. |
Arno914 |
Sep 24 2020, 12:44 AM
Member Group: Members Posts: 233 Joined: 13-May 20 From: near Frankfurt, Germany Member No.: 24,260 Region Association: Germany |
Sorry to see this. I can imagine how angry you are on yourself for not engaging first gear. (IMG:style_emoticons/default/headbang.gif)
A good bodyshop will be able to pull it out. Don´t cut the panel out and destroy the original spot welds and seam sealing I was rear ended by a drunk driver last year in my Peugeot cabriolet. The damage ist comparable to yours and was fixed within a few days. No bondo, just a bit of tin was used to even out slightly after pulling. Good luck! Arno (IMG:http://www.914world.com/bbs2/uploads_offsite/up.picr.de-24260-1600929845.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/up.picr.de-24260-1600929847.2.jpg) |
bludden |
Sep 24 2020, 07:45 AM
Thanks for the encouragement guys! Going to see what I can do this morning to get things back together and hopefully feel good enough to put it on the road to TN.
ndfrigi |
Sep 24 2020, 10:18 AM
Have you tried paintless dent guy to check if they can fix that? I watched several guy doing that kind of job and they can fix worst than that (based on the picture you have shared). For the rear bumper, try to contact ValcoOscar if he has extra he can sell from
his group bumper chroming. |
Lo-Fi Version | Time is now: 24th April 2024 - 07:41 PM |
