Question about pedal board mounting hardware |
messick |
Sep 23 2020, 04:16 PM
Newbie Group: Members Posts: 39 Joined: 15-June 20 From: Orange, CA Member No.: 24,381 Region Association: Southern California |
The pedal board in my car was pretty broken, so when I had to take it out to get access to the front panel to do my tunnel fuel line replacement, I just ripped it out and bought a new aluminum Rennline one to put in later.
Now that I'm getting ready to put that one in, I'm realizing that some of the hardware had gone missing over the last 50 years. Specifically, the the bolts/washers that hold the board/carpet to the tunnel access panel on the right, and both the bolt/washer and the trapezoidal bracket thing on the left. I guess the board had just been sitting there without being mounted for 20+ years. Checking the PET and looking up part numbers, getting a new bracket and the bolts seem doable (albeit expensive) at the bird site, but the rubber "desk pad" thing that helps hold the carpet down on the right side seems to be NLA everywhere. What do most people do if they need new hardware for this, besides not let the originals go missing? Just find bolt/washers that fit and leave out the desk pad and call it a day? Or is recommended that I go get the OEM bolts/washers and try to find a desk pad on eBay or something? |
76-914 |
Sep 23 2020, 04:40 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,485 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
The pedal board in my car was pretty broken, so when I had to take it out to get access to the front panel to do my tunnel fuel line replacement, I just ripped it out and bought a new aluminum Rennline one to put in later. Now that I'm getting ready to put that one in, I'm realizing that some of the hardware had gone missing over the last 50 years. Specifically, the the bolts/washers that hold the board/carpet to the tunnel access panel on the right, and both the bolt/washer and the trapezoidal bracket thing on the left. I guess the board had just been sitting there without being mounted for 20+ years. Checking the PET and looking up part numbers, getting a new bracket and the bolts seem doable (albeit expensive) at the bird site, but the rubber "desk pad" thing that helps hold the carpet down on the right side seems to be NLA everywhere. What do most people do if they need new hardware for this, besides not let the originals go missing? Just find bolt/washers that fit and leave out the desk pad and call it a day? Or is recommended that I go get the OEM bolts/washers and try to find a desk pad on eBay or something? Your close to @bdstone914 Give him a ring. (IMG:style_emoticons/default/beerchug.gif) |
bdstone914 |
Sep 23 2020, 05:58 PM
bdstone914 Group: Members Posts: 4,508 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@messick
date='Sep 23 2020, 03:16 PM' post='2853719'] The pedal board in my car was pretty broken, so when I had to take it out to get access to the front panel to do my tunnel fuel line replacement, I just ripped it out and bought a new aluminum Rennline one to put in later. Now that I'm getting ready to put that one in, I'm realizing that some of the hardware had gone missing over the last 50 years. Specifically, the the bolts/washers that hold the board/carpet to the tunnel access panel on the right, and both the bolt/washer and the trapezoidal bracket thing on the left. I guess the board had just been sitting there without being mounted for 20+ years. Checking the PET and looking up part numbers, getting a new bracket and the bolts seem doable (albeit expensive) at the bird site, but the rubber "desk pad" thing that helps hold the carpet down on the right side seems to be NLA everywhere. What do most people do if they need new hardware for this, besides not let the originals go missing? Just find bolt/washers that fit and leave out the desk pad and call it a day? Or is recommended that I go get the OEM bolts/washers and try to find a desk pad on eBay or something? [/quote] The right side of the pedal board attaches to a cover plate nut. I have them. I may have an extra left side trapezoidal piece. I think they are only $8 new from Pelican. The screws a common 6mm x 1.0 x 20mm cap head allen screws. |
messick |
Sep 23 2020, 06:07 PM
@messick date='Sep 23 2020, 03:16 PM' post='2853719'] The right side of the pedal board attaches to a cover plate nut. I have them. I may have an extra left side trapezoidal piece. I think they are only $8 new from Pelican. The screws a common 6mm x 1.0 x 20mm cap head allen screws. $4.50 actually. Let me know if you'd be willing to sell your extra hardware. |
Mikey914 |
Sep 24 2020, 12:18 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Make them if you need them.
https://914rubber.com/pedal-stop-for-accele...4-pedal-board-1 Also these https://914rubber.com/accelerator-pedal-sto...912-914-and-930 $6 new I know you don't need one, but we do make the pedal boards too (plywood). Some were made of particle board and were worthless. Attached thumbnail(s) |
bdstone914 |
Sep 24 2020, 07:37 AM
@messick
' date='Sep 23 2020, 05:07 PM' post='2853746'] [quote name='bdstone914' post='2853745' date='Sep 23 2020, 04:58 PM'] @messick date='Sep 23 2020, 03:16 PM' post='2853719'] The right side of the pedal board attaches to a cover plate nut. I have them. I may have an extra left side trapezoidal piece. I think they are only $8 new from Pelican. The screws a common 6mm x 1.0 x 20mm cap head allen screws. [/quote] $4.50 actually. Let me know if you'd be willing to sell your extra hardware. [/quote] I pulled an extra set of hardware. Will post a picture later to confirm all of what you need. |
messick |
Sep 24 2020, 03:29 PM
@Mikey91 Yeah, I actually saw the plate on your site earlier, and I need to buy one. What kind of rivets are those? The "just rivets" SKU on 914Rubber describes them described as "tubular" rivets, but they look like what I think of "pop" rivets. I need to buy a tool either way, so I want to make sure to order the correct one. |
bdstone914 |
Sep 25 2020, 11:14 AM
@messick
date='Sep 23 2020, 03:16 PM' post='2853719'] The right side of the pedal board attaches to a cover plate nut. I have them. I may have an extra left side trapezoidal piece. I think they are only $8 new from Pelican. The screws a common 6mm x 1.0 x 20mm cap head allen screws. [/quote] $4.50 actually. Let me know if you'd be willing to sell your extra hardware. [/quote] I pulled an extra set of hardware. Will post a picture later to confirm all of what you need. [/quote] Here is a hardwars set. I have used owdal boards if yiu need one. I am in Riverside. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 20th April 2024 - 03:42 AM |
