my battery tray and hell hole, advice? |
pt_700 |
Sep 26 2020, 03:18 PM
Senior Member Group: Members Posts: 1,086 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California |
given the caliber of 914 stewardship here, i kind of already know...
i'm in the midst of installing a "new to me" 1.7. not intended to be the "end all, be all" powertrain, this is more of a "tide me over" until i do my long intended small block conversion. as expected, i'm doing a lot of "while i'm in there..." work. after taking a wire wheel to my battery tray and hell hole, there's more of "less" in the former, while the later is still solid. battery tray support is also still solid. tray itself feels solid, i've been using it as a step to get in and out of the engine bay to do things like body to motor mount bar brackest, upgrade firewall shifter bushing, fuel lines (while i'm in there stuff) etc... is replacing the battery tray an "i can't believe you haven't done this already?!", or can i put it off a few more years (until the engine upgrade) with rust treatment? the car will almost never see rain, will be driven very occasionally and lives in a garage. anybody have a battery go "walkabout" while driving due to such a tray? if i'm convinced i should replaced the battery tray now, what's a ballpark figure for that welding job? i have a few friends that weld but, it's a bit more of a favor than i'm comfortable asking, unless my favor balance was well into the black... these particular friends have already helped me way more than i've been able to help them, my conscience dictates monetary payment. |
sholman5 |
Sep 30 2020, 02:52 PM
Kraut burner Group: Members Posts: 189 Joined: 11-September 16 From: Ormond beach, Fl. Member No.: 20,391 Region Association: South East States |
i'm liking the idea of a bolt in tray and or supports. would sure make accessing the area for cleanup easier... in order to remove both cleanly, do i simply locate & drill out the spot welds? is there access to the backsides as seen above in the rear wheel well? wow, great result to show for !!!! Did you carefully 'dremel' out the old leftovers of the old batterytray ? What kind of inserts did you use so the bolts could be used later ? Thanks for your updates and feedback ! I used a spot weld bit to remove the tray and support and ground down the spot weld. Then attached the tray to the support with a bolt that would usually secure the battery to the tray. Set the tray and support in position in the engine compartment. I pre drilled three holes at the back of the tray and the lower tab of the support. Marked the holes on the side wall of the engine compartment and the rail structure. For the tray I used the largest bolts possible, you can access the rear wheel well to put the nuts on and tighten them. The holes in the structure rail for the support depends on the size of the inserts used. Luckily for me a friend had a complete set of different size also the tool used to insert and crush the insert. I also put 2 rubber washers on every bolt used as a spacer in between the support and rail structure and tray and side wall. Hope this helps. |
Lo-Fi Version | Time is now: 19th April 2024 - 11:49 PM |
