my battery tray and hell hole, advice? |
pt_700 |
Sep 26 2020, 03:18 PM
Senior Member Group: Members Posts: 1,086 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California |
given the caliber of 914 stewardship here, i kind of already know...
i'm in the midst of installing a "new to me" 1.7. not intended to be the "end all, be all" powertrain, this is more of a "tide me over" until i do my long intended small block conversion. as expected, i'm doing a lot of "while i'm in there..." work. after taking a wire wheel to my battery tray and hell hole, there's more of "less" in the former, while the later is still solid. battery tray support is also still solid. tray itself feels solid, i've been using it as a step to get in and out of the engine bay to do things like body to motor mount bar brackest, upgrade firewall shifter bushing, fuel lines (while i'm in there stuff) etc... is replacing the battery tray an "i can't believe you haven't done this already?!", or can i put it off a few more years (until the engine upgrade) with rust treatment? the car will almost never see rain, will be driven very occasionally and lives in a garage. anybody have a battery go "walkabout" while driving due to such a tray? if i'm convinced i should replaced the battery tray now, what's a ballpark figure for that welding job? i have a few friends that weld but, it's a bit more of a favor than i'm comfortable asking, unless my favor balance was well into the black... these particular friends have already helped me way more than i've been able to help them, my conscience dictates monetary payment. |
pt_700 |
Oct 18 2020, 10:51 PM
one small step forward, two steps back... not unexpected on a 50 year old, semi-neglected car...
round 2 of wire wheel / rust treatment on the hell hole yielded much reddish dust and a similar amount of black where i'd sprayed the rust treatment. i'm hoping a new to me toy (flexible attachment for my drill to wire wheel) will allow me to get into there better. i like that right angle air grinder @mlindner has, might this be the project that drives me to pneumatic? while i wait for that new toy, i decided to install tangerine racing fuel lines. "while i was in there", i found 2 new rust spots. @superhawk996 called it, i have a perforation in my floor, under the passenger seat. i've elected to clean up the bottom, spray some rust treatment through the hole and put it on my growing "to do" list... the other spot was under the fuel tank. anyone else notice the gap seen in the last picture to the left of the fuel overflow tube? the splash tray under the steering rack was a bit bent, perhaps from an encounter with a wrecker many years ago.. having seen much worse repaired here, i know i'm fortunate. like hearing "yes, it's cancer but, having caught it early, it's very treatable...". |
Superhawk996 |
Oct 19 2020, 06:27 AM
914 Guru Group: Members Posts: 5,673 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
having seen much worse repaired here, i know i'm fortunate. like hearing "yes, it's cancer but, having caught it early, it's very treatable...". That is the right attitude. These cars all rust from the inside out and it's always pretty well hidden in the beginning. Some just rust faster than others. If you didn't have pin holes in that Hell Hole, it isn't uncommon for leaks either at window and glass seals to have allowed water in the cabin. On my car which is much further gone than what you have, I have some pinholes in the rear firewall behind the factory engine pad. Notorious rust spot. On my car, I also have a few pin holes in the driver side firewall / hell hole right about where I thought the shadows were on your car. All these can let water in the cabin. You'd be amazed at how much water can come though a tiny pin hole! You're doing the right stuff. Catch it while you can, neutralize it, seal and paint. You're second round of treatment in the hell hole looks like you've neuatralized way more rust. Good job! That small slit under the gas tank is indeed there on all cars - for drainage as previously stated. It often gets clogged and then doesn't drain properly. Yours looks pretty good. |
Lo-Fi Version | Time is now: 29th March 2024 - 07:37 AM |
