Another GT Look-a-Likey Project thread, Made a gas strut lifted air dam to clear my driveway |
john77 |
Oct 1 2020, 04:04 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Started the process of GT flaring my car this week.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589977.1.jpg) The plan is to weld all four flares on first, then widen the rears to fit 9s, and in the process strip the car panel by panel for a repaint. The rear arches had been pulled at some point in the 90s to fit 7s, and I knew they'd gone to town with bondo to smooth the driver's side out because there was a crack. The picture below is a cross section cut through the arch once I removed it... that's 0.5 inches of bondo right there (IMG:style_emoticons/default/blink.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589886.1.jpg) After making the initial rough cuts it dawned on me I'm probably going to need to remove the rear quarter oil tank to give me enough clearance to tig weld the flare on the front and back. I can only see one bolt, inside the engine bay - is that the only thing holding the tank in place? Also, dumb question, can I remove the tank without having to drain my engine oil first? I didn't think this far ahead and only changed my oil last month (IMG:style_emoticons/default/headbang.gif) |
Mayne |
Oct 13 2020, 06:07 AM
Member Group: Members Posts: 254 Joined: 28-February 17 From: NM Member No.: 20,880 Region Association: None |
Great work! I noticed in your first post that you plan to widen the rear flares for 9 inch wheels. I was under the impression that nines can work with the standard rear GT flares. Obviously tire size has a lot to do with it, but just wondering how you arrived at that decision. Cheers!
john77 |
Oct 13 2020, 09:41 AM
@Mayne I always loved the look of the privateer 914GTs running mismatched wheels with fuchs in the front and beefy minilites in the rear. But I decided to switch it up a little and run 8 inch fuchs in the front and 9 inch Group 4 campagnolos in the rear.
After speaking to 914Dave who runs the 8 inch group 4 wheels all round (see his car of the month) he told me because of the offset he had to trim the fender lip to 1/8th of an inch AND machine a tiny amount off the mounting pad on the wheel so they would fit. So going with 9s, I figure I’ll need to widen the flare. Great work! I noticed in your first post that you plan to widen the rear flares for 9 inch wheels. I was under the impression that nines can work with the standard rear GT flares. Obviously tire size has a lot to do with it, but just wondering how you arrived at that decision. Cheers! |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:36 PM |
