Another GT Look-a-Likey Project thread, Made a gas strut lifted air dam to clear my driveway |
john77 |
Oct 1 2020, 04:04 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Started the process of GT flaring my car this week.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589977.1.jpg) The plan is to weld all four flares on first, then widen the rears to fit 9s, and in the process strip the car panel by panel for a repaint. The rear arches had been pulled at some point in the 90s to fit 7s, and I knew they'd gone to town with bondo to smooth the driver's side out because there was a crack. The picture below is a cross section cut through the arch once I removed it... that's 0.5 inches of bondo right there (IMG:style_emoticons/default/blink.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589886.1.jpg) After making the initial rough cuts it dawned on me I'm probably going to need to remove the rear quarter oil tank to give me enough clearance to tig weld the flare on the front and back. I can only see one bolt, inside the engine bay - is that the only thing holding the tank in place? Also, dumb question, can I remove the tank without having to drain my engine oil first? I didn't think this far ahead and only changed my oil last month (IMG:style_emoticons/default/headbang.gif) |
sixnotfour |
Oct 13 2020, 02:04 PM
914 Wizard Group: Members Posts: 10,419 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
15x9 245/50 lips folded up,,,my other 914, are widen 1.5
Attached thumbnail(s) Attached image(s) |
john77 |
Oct 13 2020, 04:57 PM
Ahhh, okay, now I see what PanelBilly meant. I had the "removable valance" question on my brain and thought he meant that (IMG:style_emoticons/default/biggrin.gif)
I just reread the conversation I had with @914Dave and I misspoke, he's running 9s in the back just like I will be. He told me he had to have .100” machined off the mounting surface and the fender lip cut down to about 1/8”, and they only just fit with 1/16" clearance. Maybe it's because the offset is different from fuchs, i don't know. Either way, it looks like I'll have to get the mounting face machined down .100" or somehow widen the flare a little to get them to fit. One option I was thinking about was using my shrinker/stretcher on the lip to stretch them a little and then english wheeling out the flat face of the flare to give them a little more shape. Although I'm a little hesitant to alter the original shape of them too much. 15x9 245/50 lips folded up,,,my other 914, are widen 1.5 |
Lo-Fi Version | Time is now: 3rd May 2024 - 09:33 PM |
