Another GT Look-a-Likey Project thread, Made a gas strut lifted air dam to clear my driveway |
john77 |
Oct 1 2020, 04:04 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Started the process of GT flaring my car this week.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589977.1.jpg) The plan is to weld all four flares on first, then widen the rears to fit 9s, and in the process strip the car panel by panel for a repaint. The rear arches had been pulled at some point in the 90s to fit 7s, and I knew they'd gone to town with bondo to smooth the driver's side out because there was a crack. The picture below is a cross section cut through the arch once I removed it... that's 0.5 inches of bondo right there (IMG:style_emoticons/default/blink.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589886.1.jpg) After making the initial rough cuts it dawned on me I'm probably going to need to remove the rear quarter oil tank to give me enough clearance to tig weld the flare on the front and back. I can only see one bolt, inside the engine bay - is that the only thing holding the tank in place? Also, dumb question, can I remove the tank without having to drain my engine oil first? I didn't think this far ahead and only changed my oil last month (IMG:style_emoticons/default/headbang.gif) |
john77 |
Oct 12 2020, 10:21 PM
I'm going to be getting a new front valance to match the shape of the flares, but I have a problem...
The driveway up the side of my house to my garage in the back is pretty steep, and the valance I have on the car now scrapes across the sidewalk as I hit the bottom of the driveway. I'm wondering if there's a way I can make the valance quick release, so I can take it off when I drive in and out of my house? But not so quick release that it flies off on the 405 (IMG:style_emoticons/default/bye1.gif) Dzus fasteners maybe? Has anyone done this? |
campbellcj |
Oct 17 2020, 07:54 AM
I can't Re Member Group: Members Posts: 4,543 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I'm going to be getting a new front valance to match the shape of the flares, but I have a problem... The driveway up the side of my house to my garage in the back is pretty steep, and the valance I have on the car now scrapes across the sidewalk as I hit the bottom of the driveway. I'm wondering if there's a way I can make the valance quick release, so I can take it off when I drive in and out of my house? But not so quick release that it flies off on the 405 (IMG:style_emoticons/default/bye1.gif) Dzus fasteners maybe? Has anyone done this? Mine is set up as semi-quick release - I used two dzus fasteners on the L/R sides but ended up using screws w/ nutserts in front for added security. It comes on/off within a couple mins unless I have the brake ducts connected, for which I haven't yet figured out a quick-release setup. I did this for trailer ramp clearance many years ago. |
Lo-Fi Version | Time is now: 5th May 2024 - 03:15 PM |
