Another GT Look-a-Likey Project thread, Made a gas strut lifted air dam to clear my driveway |
john77 |
Oct 1 2020, 04:04 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Started the process of GT flaring my car this week.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589977.1.jpg) The plan is to weld all four flares on first, then widen the rears to fit 9s, and in the process strip the car panel by panel for a repaint. The rear arches had been pulled at some point in the 90s to fit 7s, and I knew they'd gone to town with bondo to smooth the driver's side out because there was a crack. The picture below is a cross section cut through the arch once I removed it... that's 0.5 inches of bondo right there (IMG:style_emoticons/default/blink.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589886.1.jpg) After making the initial rough cuts it dawned on me I'm probably going to need to remove the rear quarter oil tank to give me enough clearance to tig weld the flare on the front and back. I can only see one bolt, inside the engine bay - is that the only thing holding the tank in place? Also, dumb question, can I remove the tank without having to drain my engine oil first? I didn't think this far ahead and only changed my oil last month (IMG:style_emoticons/default/headbang.gif) |
john77 |
Feb 1 2021, 02:21 PM
Can't believe I started this in October - I've been making slow progress so figured I'd post an update.
Right now I have both front flares on and epoxied, and the wheel wells stripped to bare metal and painted with POR15. Everything's taking longer than expected though because it turns out the entire car was covered in a thick layer of bondo, and as I'm stripping it I'm finding a bunch of stuff. Luckily, it wasn't hiding any terrible rot, just some bad previous "repairs" that I'm having to correct as I go along. To give an idea of how much bondo, this was the passenger rear quarter after I'd stripped most of it off, and it appears the entire car is like this: (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1612210885.1.jpg) |
Lo-Fi Version | Time is now: 7th May 2024 - 10:54 PM |
