Another GT Look-a-Likey Project thread, Made a gas strut lifted air dam to clear my driveway |
john77 |
Oct 1 2020, 04:04 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Started the process of GT flaring my car this week.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589977.1.jpg) The plan is to weld all four flares on first, then widen the rears to fit 9s, and in the process strip the car panel by panel for a repaint. The rear arches had been pulled at some point in the 90s to fit 7s, and I knew they'd gone to town with bondo to smooth the driver's side out because there was a crack. The picture below is a cross section cut through the arch once I removed it... that's 0.5 inches of bondo right there (IMG:style_emoticons/default/blink.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589886.1.jpg) After making the initial rough cuts it dawned on me I'm probably going to need to remove the rear quarter oil tank to give me enough clearance to tig weld the flare on the front and back. I can only see one bolt, inside the engine bay - is that the only thing holding the tank in place? Also, dumb question, can I remove the tank without having to drain my engine oil first? I didn't think this far ahead and only changed my oil last month (IMG:style_emoticons/default/headbang.gif) |
mepstein |
Oct 2 2020, 01:20 PM
914-6 GT in waiting Group: Members Posts: 19,239 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Front right is passenger
Right and left is always as if you are sitting in car. |
john77 |
Oct 2 2020, 01:47 PM
mepstein |
Oct 2 2020, 05:43 PM
You’d think that, right? But after rough fitting, the flare marked “front right” only fits on the driver side. Front right is passenger Right and left is always as if you are sitting in car. Well I know that but I can't speak to the flare being mislabeled. |
john77 |
Oct 2 2020, 05:59 PM
@mepstein Sorry, wasn’t having a pop at you, I appreciate you chiming in. You’re probably right on the mislabelling. A little frustrating as the measurements didn’t seem to match up either. I’ll just have to triple check when I’m doing the rears.
john77 |
Oct 2 2020, 06:00 PM
@mepstein Sorry, wasn’t having a pop at you, I appreciate you chiming in. You’re probably right on the mislabelling. A little frustrating as the measurements didn’t seem to match up either but I got there in the end. I’ll just have to triple check when I’m doing the rears. You’d think that, right? But after rough fitting, the flare marked “front right” only fits on the driver side. Front right is passenger Right and left is always as if you are sitting in car. Well I know that but I can't speak to the flare being mislabeled. |
Lo-Fi Version | Time is now: 26th April 2024 - 10:43 AM |
