Another GT Look-a-Likey Project thread, Made a gas strut lifted air dam to clear my driveway |
john77 |
Oct 1 2020, 04:04 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Started the process of GT flaring my car this week.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589977.1.jpg) The plan is to weld all four flares on first, then widen the rears to fit 9s, and in the process strip the car panel by panel for a repaint. The rear arches had been pulled at some point in the 90s to fit 7s, and I knew they'd gone to town with bondo to smooth the driver's side out because there was a crack. The picture below is a cross section cut through the arch once I removed it... that's 0.5 inches of bondo right there (IMG:style_emoticons/default/blink.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589886.1.jpg) After making the initial rough cuts it dawned on me I'm probably going to need to remove the rear quarter oil tank to give me enough clearance to tig weld the flare on the front and back. I can only see one bolt, inside the engine bay - is that the only thing holding the tank in place? Also, dumb question, can I remove the tank without having to drain my engine oil first? I didn't think this far ahead and only changed my oil last month (IMG:style_emoticons/default/headbang.gif) |
mlindner |
Oct 4 2020, 09:26 AM
Senior Member Group: Members Posts: 1,511 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
John77, Ben (mb911) has already made the ends for you. They are pretty complex so you only need to weld them on to match the flares final position. Mepstein also has Bens flared rocker ends. Best, Mark
john77 |
Oct 4 2020, 10:11 AM
Thanks Mark.
@mb911 , definitely want a set of these if they’re available Ben - I’ll pm you. [EDIT: Ignore that, found your website and ordered a set.] John77, Ben (mb911) has already made the ends for you. They are pretty complex so you only need to weld them on to match the flares final position. Mepstein also has Bens flared rocker ends. Best, Mark |
Tdskip |
Oct 4 2020, 12:01 PM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Thanks Mark. @mb911 , definitely want a set of these if they’re available Ben - I’ll pm you. [EDIT: Ignore that, found your website and ordered a set.] John77, Ben (mb911) has already made the ends for you. They are pretty complex so you only need to weld them on to match the flares final position. Mepstein also has Bens flared rocker ends. Best, Mark Good decision, worth the time saved even before factoring in the risk of messing it up. |
Lo-Fi Version | Time is now: 23rd April 2024 - 11:47 PM |
