Another GT Look-a-Likey Project thread, Made a gas strut lifted air dam to clear my driveway |
john77 |
Oct 1 2020, 04:04 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Started the process of GT flaring my car this week.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589977.1.jpg) The plan is to weld all four flares on first, then widen the rears to fit 9s, and in the process strip the car panel by panel for a repaint. The rear arches had been pulled at some point in the 90s to fit 7s, and I knew they'd gone to town with bondo to smooth the driver's side out because there was a crack. The picture below is a cross section cut through the arch once I removed it... that's 0.5 inches of bondo right there (IMG:style_emoticons/default/blink.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589886.1.jpg) After making the initial rough cuts it dawned on me I'm probably going to need to remove the rear quarter oil tank to give me enough clearance to tig weld the flare on the front and back. I can only see one bolt, inside the engine bay - is that the only thing holding the tank in place? Also, dumb question, can I remove the tank without having to drain my engine oil first? I didn't think this far ahead and only changed my oil last month (IMG:style_emoticons/default/headbang.gif) |
Cairo94507 |
Oct 13 2020, 07:10 AM
Michael Group: Members Posts: 9,703 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Keep a 4x4 post near your driveway and drop it into the gutter area so it reduces the drop off gradually. Or there are a lot of gutter slope/driveway rubber devises available to change the slope so it is an easy rise.
john77 |
Oct 13 2020, 09:51 AM
@Cairo94507
The problem isn't so much the gutter, more that the entire car is on an incline as it meets the sidewalk. So with the rear elevated, the nose just grinds into the abruptly level concrete. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1602605990.1.jpg) That said, the ramp idea could be a smarter alternative. Thanks, I'll look into it. Keep a 4x4 post near your driveway and drop it into the gutter area so it reduces the drop off gradually. Or there are a lot of gutter slope/driveway rubber devises available to change the slope so it is an easy rise. |
Lo-Fi Version | Time is now: 19th April 2024 - 09:49 PM |
