Another GT Look-a-Likey Project thread, Made a gas strut lifted air dam to clear my driveway |
john77 |
Oct 1 2020, 04:04 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Started the process of GT flaring my car this week.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589977.1.jpg) The plan is to weld all four flares on first, then widen the rears to fit 9s, and in the process strip the car panel by panel for a repaint. The rear arches had been pulled at some point in the 90s to fit 7s, and I knew they'd gone to town with bondo to smooth the driver's side out because there was a crack. The picture below is a cross section cut through the arch once I removed it... that's 0.5 inches of bondo right there (IMG:style_emoticons/default/blink.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589886.1.jpg) After making the initial rough cuts it dawned on me I'm probably going to need to remove the rear quarter oil tank to give me enough clearance to tig weld the flare on the front and back. I can only see one bolt, inside the engine bay - is that the only thing holding the tank in place? Also, dumb question, can I remove the tank without having to drain my engine oil first? I didn't think this far ahead and only changed my oil last month (IMG:style_emoticons/default/headbang.gif) |
Literati914 |
Oct 17 2020, 10:32 AM
Senior Member Group: Members Posts: 1,428 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
@Literati914 ..block when I’m ready for color/clear. Can you sand color? I was under the impression if you do you have to do another coat or it will show through the clear. Ok so you're using base and clear, the clear would be wet sanded not the color .. and for that reason rolling paint on may be even less of a good idea - might not work out so great if the color is lumpy and the clear as well. It may be doable though with a single stage, we'll see. Good luck with your project. |
Lo-Fi Version | Time is now: 19th April 2024 - 10:07 PM |
