Another GT Look-a-Likey Project thread, Made a gas strut lifted air dam to clear my driveway |
john77 |
Oct 1 2020, 04:04 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Started the process of GT flaring my car this week.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589977.1.jpg) The plan is to weld all four flares on first, then widen the rears to fit 9s, and in the process strip the car panel by panel for a repaint. The rear arches had been pulled at some point in the 90s to fit 7s, and I knew they'd gone to town with bondo to smooth the driver's side out because there was a crack. The picture below is a cross section cut through the arch once I removed it... that's 0.5 inches of bondo right there (IMG:style_emoticons/default/blink.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589886.1.jpg) After making the initial rough cuts it dawned on me I'm probably going to need to remove the rear quarter oil tank to give me enough clearance to tig weld the flare on the front and back. I can only see one bolt, inside the engine bay - is that the only thing holding the tank in place? Also, dumb question, can I remove the tank without having to drain my engine oil first? I didn't think this far ahead and only changed my oil last month (IMG:style_emoticons/default/headbang.gif) |
john77 |
Feb 1 2021, 02:35 PM
I'm really happy with the way the passenger side front flare turned out, which means I'll probably end up circling back to get the driver side up to the same level of finish. The transitions from the fender into the flare all flow nicely and should need a minimal amount of filler.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1612211720.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1612211721.2.jpg) After stripping the door I found some previous damage that had been repaired pretty badly. There were two drill holes (I'm assuming they were made to pull a dent) that were then just left and filled with filler. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1612211722.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1612211722.4.jpg) Because of the crash support behind the skin I'm not 100% sure how to deal with this one. The door skin is pretty lumpy and it may make more sense to find a replacement door - I've epoxied it for now and will figure out what the best fix is once the time comes. |
Lo-Fi Version | Time is now: 27th April 2024 - 07:15 AM |
