Another GT Look-a-Likey Project thread, Made a gas strut lifted air dam to clear my driveway |
john77 |
Oct 1 2020, 04:04 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Started the process of GT flaring my car this week.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589977.1.jpg) The plan is to weld all four flares on first, then widen the rears to fit 9s, and in the process strip the car panel by panel for a repaint. The rear arches had been pulled at some point in the 90s to fit 7s, and I knew they'd gone to town with bondo to smooth the driver's side out because there was a crack. The picture below is a cross section cut through the arch once I removed it... that's 0.5 inches of bondo right there (IMG:style_emoticons/default/blink.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589886.1.jpg) After making the initial rough cuts it dawned on me I'm probably going to need to remove the rear quarter oil tank to give me enough clearance to tig weld the flare on the front and back. I can only see one bolt, inside the engine bay - is that the only thing holding the tank in place? Also, dumb question, can I remove the tank without having to drain my engine oil first? I didn't think this far ahead and only changed my oil last month (IMG:style_emoticons/default/headbang.gif) |
john77 |
Jun 3 2021, 02:33 PM
I finally got the flares finished, can't believe it's 8 months since I started this thread. I mean, I can, because everything takes me way longer than I think, but still...
The car is going to be in epoxy for a while while I get other random projects done like making a custom front grille, fog light grilles, redoing my engine GT engine lid, making a new oil cooler shroud, and most importantly replacing the hammered sh*t door skins with new FG door skins. The driver's side door was certainly a highlight so far. To look at the car you never would have known there was bondo on it, yet somehow this survived 20+ years without cracking and I ended up using a hammer and chisel to remove it. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1622752401.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1622752402.2.jpg) |
Lo-Fi Version | Time is now: 27th April 2024 - 07:15 AM |
