Another GT Look-a-Likey Project thread, Made a gas strut lifted air dam to clear my driveway |
john77 |
Oct 1 2020, 04:04 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Started the process of GT flaring my car this week.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589977.1.jpg) The plan is to weld all four flares on first, then widen the rears to fit 9s, and in the process strip the car panel by panel for a repaint. The rear arches had been pulled at some point in the 90s to fit 7s, and I knew they'd gone to town with bondo to smooth the driver's side out because there was a crack. The picture below is a cross section cut through the arch once I removed it... that's 0.5 inches of bondo right there (IMG:style_emoticons/default/blink.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589886.1.jpg) After making the initial rough cuts it dawned on me I'm probably going to need to remove the rear quarter oil tank to give me enough clearance to tig weld the flare on the front and back. I can only see one bolt, inside the engine bay - is that the only thing holding the tank in place? Also, dumb question, can I remove the tank without having to drain my engine oil first? I didn't think this far ahead and only changed my oil last month (IMG:style_emoticons/default/headbang.gif) |
john77 |
Jun 3 2021, 02:39 PM
Some other stuff I got done...
Stripped all 4 wheel wells and then prepped with rust mort, painted with POR15, and then coated with Raptor bedliner. I know a people either love or hate POR15 but I've found the trick with it is that you always have to etch the metal first as it absolutely hates bare metal and that's when it peels off in sheets. For the Raptor, I just waited an hour until the POR15 was still a tiny bit tacky and they rolled it on with a low nap roller - I had the spray gun but couldn't be bother with masking everything up to stop overspray, and the instructions say you can just mix it up and paint it on too. So far, no issues, and it's solid as a rock. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1622752768.1.jpg) |
Lo-Fi Version | Time is now: 27th April 2024 - 01:37 AM |
