Another GT Look-a-Likey Project thread, Made a gas strut lifted air dam to clear my driveway |
john77 |
Oct 1 2020, 04:04 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
Started the process of GT flaring my car this week.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589977.1.jpg) The plan is to weld all four flares on first, then widen the rears to fit 9s, and in the process strip the car panel by panel for a repaint. The rear arches had been pulled at some point in the 90s to fit 7s, and I knew they'd gone to town with bondo to smooth the driver's side out because there was a crack. The picture below is a cross section cut through the arch once I removed it... that's 0.5 inches of bondo right there (IMG:style_emoticons/default/blink.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1601589886.1.jpg) After making the initial rough cuts it dawned on me I'm probably going to need to remove the rear quarter oil tank to give me enough clearance to tig weld the flare on the front and back. I can only see one bolt, inside the engine bay - is that the only thing holding the tank in place? Also, dumb question, can I remove the tank without having to drain my engine oil first? I didn't think this far ahead and only changed my oil last month (IMG:style_emoticons/default/headbang.gif) |
john77 |
Jun 3 2021, 02:51 PM
The bottoms of the flares didn't run in a straight line with the bottom edge of the fender, instead they slightly sloped down.
This was going to be an issue if I wanted a consistent gap between the top of the rocker and the rear fender once it was flared, so I decided to chop the ends off and remake them straight. I probably could have just made a few cuts, hammered the edge straight and rewelded them, but getting a really sharp line like the bottom of the fender would have been tough, and sometimes I like to make more work for myself. (IMG:style_emoticons/default/biggrin.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1622753458.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1622753459.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1622753459.3.jpg) This is one done and test fitted to the car. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-17027-1622753460.4.jpg) |
Lo-Fi Version | Time is now: 27th April 2024 - 06:13 AM |
