6 swap Oil Pressure / Temp Combo Gauge Options? |
RichPugh |
Oct 6 2020, 09:25 AM
Member Group: Members Posts: 121 Joined: 28-October 14 From: Baltimore, MD Member No.: 18,068 Region Association: MidAtlantic Region |
About a year ago, I spoke with Palo Alto Speedometer about their 914/6 triple cluster gauge. I assume it is still avail. Is there any other option to get a combo gauge for a 914/6 application with Fuel level, oil pressure and oil temp readings? I'm eliminating the center console in my car and would like one clean simple gauge if possible. I also saw the option of getting a standard 911 oil temp/pressure gauge and modifying a 930 tach to change the boost gauge portion of it to be the fuel gauge.
This one is my first choice... Just checking to see if there were options or anyone selling one similar. - Rich This would be my first option... (IMG:http://www.914world.com/bbs2/uploads_offsite/www.paspeedo.com-18068-1601997930.1.jpg) These would be my 2nd option... Converting the Bar boost gauge into a fuel gauge. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.ebayimg.com-18068-1601997931.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.ebayimg.com-18068-1601997932.3.jpg) |
targa72e |
Oct 14 2020, 08:16 PM
Member Group: Members Posts: 258 Joined: 11-September 16 From: colorado Member No.: 20,392 Region Association: None |
I am not sure it you could reverse it electronically. You would still need the spring to want the gauge to read zero on the other side. Could probably use a different movement and change the electronics to match the fuel sender.
john |
Lo-Fi Version | Time is now: 25th April 2024 - 04:22 AM |
