| eric9144 |
Dec 16 2020, 01:11 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,802 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California
Got the roof texture and color right after the 4th attempt (IMG:style_emoticons/default/beerchug.gif)
Was harder to get the texture dialed in than I expected, had to be thined down a bunch and then knocked down at the end slightly to get it right. Ordered up new rubber and a headliner from 914rubber on black Friday as well as latch HW and screws from Bruce Stone, should have the roof back this coming weekend (IMG:style_emoticons/default/first.gif) ![]() |
| johnhora |
Dec 16 2020, 02:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 909 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None
Eric...that looks great!
| Retroracer |
Dec 16 2020, 07:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 669 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest
How much heat and cold transmits through the roof top? I was contemplating using Noico 150 mil insulation padding under the headliner material. I was running just a bare shell in the GT replica. but was noticing much heat transfer in hot CA sun. Given that most of the miles in are on the road, not the track, I decided to add some insulation. I ordered a headliner piece from 914rubber, but prior to gluing it in, put in a layer of Dynaliner (.25" thick), which is a closed cell foam heat insulation product. It comes with a self adhesive backing and can be cut to shape easily. Worked a treat and hides under the factory looking living material nicely. No data on surface temp differential numbers to hand, but a few times this summer the temp difference between inside and outside targa temps was easily felt. FYI, - Tony PS. Was interested to learn on this thread that the early/late tops are tied into the early/late doors & window winders. Think I may have the wrong top type on now (which may explain the generous window gaps...!) |
| ahycaramba |
Dec 18 2020, 07:35 PM
“I live my life a quarter mile at a time.” ![]() ![]() Group: Members Posts: 161 Joined: 17-March 15 From: Murrieta, California Member No.: 18,534 Region Association: Southern California
How much heat and cold transmits through the roof top? I was contemplating using Noico 150 mil insulation padding under the headliner material. I was running just a bare shell in the GT replica. but was noticing much heat transfer in hot CA sun. Given that most of the miles in are on the road, not the track, I decided to add some insulation. I ordered a headliner piece from 914rubber, but prior to gluing it in, put in a layer of Dynaliner (.25" thick), which is a closed cell foam heat insulation product. It comes with a self adhesive backing and can be cut to shape easily. Worked a treat and hides under the factory looking living material nicely. No data on surface temp differential numbers to hand, but a few times this summer the temp difference between inside and outside targa temps was easily felt. FYI, - Tony PS. Was interested to learn on this thread that the early/late tops are tied into the early/late doors & window winders. Think I may have the wrong top type on now (which may explain the generous window gaps...!) Thanks Tony for answering to my question about insulation to the top. I'll definatly follow suite. I'll be running without ac and heat for a while so I have to do everything I can to make it as comfortable as possible. |
| ahycaramba |
Dec 18 2020, 07:40 PM
Does anybody know where I can source a nice pair of horizontal targa top track to top of window seals?
Thanks in advance. Al |
Lo-Fi Version | Time is now: 26th October 2026 - 09:04 PM |
