RolinkHaus |
Member ![]() ![]() Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None ![]() |
WTB: Engine Lift Support or something similiar.
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,023 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,505 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
RolinkHaus |
Thanks, I am assuming I can use this to install that flat6 also?
GregAmy |
Dominic |
Dominic ![]() ![]() ![]() Group: Members Posts: 993 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California ![]() |
pt_700 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,108 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California ![]() ![]() |
Thanks, I am assuming I can use this to install that flat6 also? Get yourself an ATV jack from Harbor Freight, works well for both -6 and -4 engines. one of these? https://www.harborfreight.com/1500-lb-steel...lift-60536.html i'm getting closer to drivetrain install and lacking confidence in the home made wooden bracket i used for removal with a rolling floor jack... i'm guessing you put the lift in with the pedals toward the front of the car? where do you position the engine / trans unit for optimal balance with a 4? |
Dominic |
Thanks, I am assuming I can use this to install that flat6 also? Get yourself an ATV jack from Harbor Freight, works well for both -6 and -4 engines. one of these? https://www.harborfreight.com/1500-lb-steel...lift-60536.html i'm getting closer to drivetrain install and lacking confidence in the home made wooden bracket i used for removal with a rolling floor jack... i'm guessing you put the lift in with the pedals toward the front of the car? where do you position the engine / trans unit for optimal balance with a 4? https://www.harborfreight.com/1500-lb-alumi...lift-63397.html This is the one I use, but usually have a floor jack under the trans for the 914. |
Lo-Fi Version | Time is now: 4th July 2025 - 09:20 AM |
