Engine Lift Support, Tool |
RolinkHaus |
Oct 15 2020, 09:07 AM
Member Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None |
WTB: Engine Lift Support or something similiar.
RolinkHaus |
Oct 15 2020, 11:45 AM
Thanks, I am assuming I can use this to install that flat6 also?
Dominic |
Oct 15 2020, 08:29 PM
Dominic Group: Members Posts: 991 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
pt_700 |
Oct 16 2020, 10:10 PM
Senior Member Group: Members Posts: 1,090 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California |
Thanks, I am assuming I can use this to install that flat6 also? Get yourself an ATV jack from Harbor Freight, works well for both -6 and -4 engines. one of these? https://www.harborfreight.com/1500-lb-steel...lift-60536.html i'm getting closer to drivetrain install and lacking confidence in the home made wooden bracket i used for removal with a rolling floor jack... i'm guessing you put the lift in with the pedals toward the front of the car? where do you position the engine / trans unit for optimal balance with a 4? |
Dominic |
Oct 16 2020, 11:12 PM
Thanks, I am assuming I can use this to install that flat6 also? Get yourself an ATV jack from Harbor Freight, works well for both -6 and -4 engines. one of these? https://www.harborfreight.com/1500-lb-steel...lift-60536.html i'm getting closer to drivetrain install and lacking confidence in the home made wooden bracket i used for removal with a rolling floor jack... i'm guessing you put the lift in with the pedals toward the front of the car? where do you position the engine / trans unit for optimal balance with a 4? https://www.harborfreight.com/1500-lb-alumi...lift-63397.html This is the one I use, but usually have a floor jack under the trans for the 914. |
Lo-Fi Version | Time is now: 25th April 2024 - 05:40 PM |
