JPMcClelland |
I'm new here ... Group: Members Posts: 0 Joined: 15-October 20 From: Walnut Creek, CA Member No.: 24,768 Region Association: Northern California ![]() |
971 914-6 Conversion
Engine: -- 3.2 from an '87 Carrera -- 70-75 hours on rebuild -- Stock DME injection (Steve Wong chip) -- Extrude honed intake manifolds (Steve Weiner) -- All new injectors, hoses, fuel pressure regulator at rebuild -- Web-Cam #20/21 cams -- "European" (not 906 style) headers -- Coast Fab 11" mufflers -- Mocal thermostat -- Fluidyne front oil cooler -- 91 pump gas -- 227 whp; 14 hp driveline drag -- Alan Johnson style front engine mount (welded in) w/ Wevo mounts Transmission: -- '73 901 -- side shifter -- stock ratios -- LSD -- billet aluminum intermediate plate -- Kennedy 6 puck disc -- shortened 930 axles -- Wevo rear mounts -- '84 915 included (but needs to be set up for a 914) Wheels / Tires / Brakes: -- Fuchs 951 8x16 in front, 911 9x16 rear -- Toyo RR: 225/45-16 front, 245/40-16 rear -- 951 rotors and calipers front and rear -- Pagid orange pads -- Mercedes 23 mm master cylinder -- Wilwood adjustable bias valve -- Pedal box rebushed 2019 Suspension: -- Bilstein sport shocks -- 250 lb. rear springs -- 23 mm front torsion bars -- Tarrett adjustable front sway bar (no rear bar) -- Delrin bushings (front and rear) -- Tarrett front camber plates (-1.8 front, -2.5 rear) Body: -- TC Design roll cage -- steel replica GT fender flares -- replica 914-6 oil tank -- fiberglass rocker panels, front and rear valances -- fiberglass front and rear trunk lids (pinned, no hinges) -- fiberglass top -- windshield = only glass -- Sparco Pro ADV seats -- Schroth harnesses -- Momo alcantara steering wheel; Smart Racing quick release Unofficially, 1:42's at Laguna, 2:05's at Thunderhill Additional photos and other info on request $33,000 or best offer Attached thumbnail(s) ![]() Attached image(s) ![]() |
Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,114 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() |
Please makes sure to include a price.
a9146luvr |
Member ![]() ![]() Group: Members Posts: 52 Joined: 2-January 04 Member No.: 1,495 Region Association: None ![]() |
Got more pictures? Streetlegalable? Nice tho! (IMG:style_emoticons/default/smile.gif)
jmz |
Member ![]() ![]() Group: Members Posts: 132 Joined: 11-April 16 From: Lone Star State Member No.: 19,886 Region Association: None ![]() |
Email sent
DANNYMAC |
Member ![]() ![]() Group: Members Posts: 86 Joined: 8-July 20 From: NORTH HOLLYWOOD CALIFORNIA Member No.: 24,470 Region Association: Southern California ![]() |
jmz |
emailed,commented here and sent P.M. ...ghosted.
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,540 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
That 33 about covers the engine?
jmz |
Tdskip |
That 33 about covers the engine? It is just a 3.2 motronic... so I'd say no. That is a fair price for the car. If you had to source and rebuild the engine and transmission to this spec not sure you'd get much change back from $30k in SoCal anyway. Sorry I missed the price in the listing. |
jmz |
That 33 about covers the engine? It is just a 3.2 motronic... so I'd say no. That is a fair price for the car. If you had to source and rebuild the engine and transmission to this spec not sure you'd get much change back from $30k in SoCal anyway. Sorry I missed the price in the listing. True enough but still fairly priced. The car is so close to vintage race specs with the cage and all that if I bought it I’d sell the engine anyway and put a 2.5ish twin plug in it depending on what class iI would run it. |
a9146luvr |
Yeah, "ghosted" in late October by a pumpkin, scary or surprised? (IMG:style_emoticons/default/happy11.gif)
HowLamb |
I'm new here ... Group: Members Posts: 0 Joined: 11-July 20 From: UK Member No.: 24,481 Region Association: England ![]() |
Hi, is the car still available?
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,366 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: None ![]() ![]() |
Always confused when someone builds a “track car” but it isn’t built to a set of rules
But you could change out the motor and still turn it into a legal race car |
flat4guy |
Member ![]() ![]() Group: Members Posts: 297 Joined: 10-October 16 From: nor cal Member No.: 20,484 Region Association: Northern California ![]() |
Lo-Fi Version | Time is now: 26th February 2021 - 09:42 PM |
