1971 914-6 Track Car For Sale |
JPMcClelland |
Oct 15 2020, 12:13 PM
I'm new here ... Group: Members Posts: 0 Joined: 15-October 20 From: Walnut Creek, CA Member No.: 24,768 Region Association: Northern California |
971 914-6 Conversion
Engine: -- 3.2 from an '87 Carrera -- 70-75 hours on rebuild -- Stock DME injection (Steve Wong chip) -- Extrude honed intake manifolds (Steve Weiner) -- All new injectors, hoses, fuel pressure regulator at rebuild -- Web-Cam #20/21 cams -- "European" (not 906 style) headers -- Coast Fab 11" mufflers -- Mocal thermostat -- Fluidyne front oil cooler -- 91 pump gas -- 227 whp; 14 hp driveline drag -- Alan Johnson style front engine mount (welded in) w/ Wevo mounts Transmission: -- '73 901 -- side shifter -- stock ratios -- LSD -- billet aluminum intermediate plate -- Kennedy 6 puck disc -- shortened 930 axles -- Wevo rear mounts -- '84 915 included (but needs to be set up for a 914) Wheels / Tires / Brakes: -- Fuchs 951 8x16 in front, 911 9x16 rear -- Toyo RR: 225/45-16 front, 245/40-16 rear -- 951 rotors and calipers front and rear -- Pagid orange pads -- Mercedes 23 mm master cylinder -- Wilwood adjustable bias valve -- Pedal box rebushed 2019 Suspension: -- Bilstein sport shocks -- 250 lb. rear springs -- 23 mm front torsion bars -- Tarrett adjustable front sway bar (no rear bar) -- Delrin bushings (front and rear) -- Tarrett front camber plates (-1.8 front, -2.5 rear) Body: -- TC Design roll cage -- steel replica GT fender flares -- replica 914-6 oil tank -- fiberglass rocker panels, front and rear valances -- fiberglass front and rear trunk lids (pinned, no hinges) -- fiberglass top -- windshield = only glass -- Sparco Pro ADV seats -- Schroth harnesses -- Momo alcantara steering wheel; Smart Racing quick release Unofficially, 1:42's at Laguna, 2:05's at Thunderhill Additional photos and other info on request $33,000 or best offer Attached thumbnail(s) Attached image(s) |
flat4guy |
Dec 12 2020, 09:20 PM
Member Group: Members Posts: 442 Joined: 10-October 16 From: nor cal Member No.: 20,484 Region Association: Northern California |
Lo-Fi Version | Time is now: 26th April 2024 - 10:42 AM |
