ahycaramba |
“I live my life a quarter mile at a time.” ![]() ![]() Group: Members Posts: 161 Joined: 17-March 15 From: Murrieta, California Member No.: 18,534 Region Association: Southern California ![]() ![]() |
I am contemplating on interior design on an open canvas of a 914 interior. Looking for any ideals. I am wanting to know what the RS inner door handles look like. If anybody wants to chime in and show me what you have I would gladly appreciate it. My color scheme is black, gray, and red.
Thanks Al Attached thumbnail(s) ![]() |
RolinkHaus |
Member ![]() ![]() Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None ![]() |
I like it aaaaa lot
Costa05 |
Member ![]() ![]() Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region ![]() ![]() |
Mine are about done here. Lots of hours but redid the entire door panels with it. Ended up fabricating the door pull mechanism too. Not an easy task. Fiberglass trim pieces to cover up my mechanism, but turned out nice. Have not cut out the window cranks yet.
Attached image(s) ![]() |
VegasRacer |
ELVIRA ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,899 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None ![]() ![]() ![]() |
![]() Door latches were flipped to allow for clearance with the roll cage. ![]() |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I’m doing up a set now for a customer and will post up Monday.
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,807 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
ahycaramba |
I am loving the look gentlemen! One thing the strap. On Costa05's car he fabricated the pull strap. (nicely done BTW). Let me get this right... The pull strap is not plug and play you will have to figure out how to intertwine the door lock and release lever to make it work. Am I correct?
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,096 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Mine are about done here. Lots of hours but redid the entire door panels with it. Ended up fabricating the door pull mechanism too. Not an easy task. Fiberglass trim pieces to cover up my mechanism, but turned out nice. Have not cut out the window cranks yet. @Costa05 That is very nice. |
Costa05 |
I am loving the look gentlemen! One thing the strap. On Costa05's car he fabricated the pull strap. (nicely done BTW). Let me get this right... The pull strap is not plug and play you will have to figure out how to intertwine the door lock and lease lever to make it work. Am I correct? Thanks Definitely not plug and play on mine! Someone likely has the perfect easy solution already that I missed for the loop style pull strap... like you, I would love to see their ideas. (IMG:style_emoticons/default/beerchug.gif) |
Maltese Falcon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None ![]() ![]() |
Maltese Falcon |
Maltese Falcon |
I am loving the look gentlemen! One thing the strap. On Costa05's car he fabricated the pull strap. (nicely done BTW). Let me get this right... The pull strap is not plug and play you will have to figure out how to intertwine the door lock and release lever to make it work. Am I correct? Any custom door pull will require the Action of pulling on the spring loaded arm in the door mechanism. Check out the way we did a basic door pull on our current build*...the red Rennline key strap to the rescue ! *the white 9148 gtt, I think that you just got to see the body parts of it when you visited with your Son (IMG:style_emoticons/default/smile.gif) ![]() ![]() |
Costa05 |
I am loving the look gentlemen! One thing the strap. On Costa05's car he fabricated the pull strap. (nicely done BTW). Let me get this right... The pull strap is not plug and play you will have to figure out how to intertwine the door lock and release lever to make it work. Am I correct? Any custom door pull will require the Action of pulling on the spring loaded arm in the door mechanism. Check out the way we did a basic door pull on our current build*...the red Rennline key strap to the rescue ! *the white 9148 gtt, I think that you just got to see the body parts of it when you visited with your Son (IMG:style_emoticons/default/smile.gif) ![]() ![]() Clever solution! On mine I recreated the mechanics of the stock handle using metal pivot arm and the existing rod. Then had to hide it somehow. It was a bit complicated and time consuming. |
Mikey914 |
Took a little longer than planned as we are down an employee. She got a better job offer so can't fault her there but finally done -
Shown with handles not attaches as we will leave that up to the customer for how and where they want to mount and it should really mount to the metal. Attached thumbnail(s) ![]() ![]() ![]() |
Mikey914 |
And we can do a double stitch in a diagonal pattern but it would be a special order
eric9144 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,771 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California ![]() ![]() |
RFoulds |
914Rennsport ![]() ![]() ![]() Group: Members Posts: 858 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region ![]() ![]() |
Took a little longer than planned as we are down an employee. She got a better job offer so can't fault her there but finally done - Shown with handles not attaches as we will leave that up to the customer for how and where they want to mount and it should really mount to the metal. Love these. Perfect for my race car when I convert it back to a street legal hot rod. especially since I have no windows or window cranks. HOW MUCH?? |
Mikey914 |
We just charge for the kit and a set of panels We currently combine at no extra charge. May take 2 weeks but times will get better.
https://914rubber.com/upholstered-door-panel-set-for-914 Just need to note smooth and order the Kit too https://914rubber.com/upholstered-door-panel-set-for-914 https://914rubber.com/rs-inner-door-handle-kit |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,768 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
VW Beetle door * pulls , I had covered in black leather. Flipped over door handles...easier to actuate when the side (cage) bars are bolted in; and shorty window cranks to operate with the interior verticle bar. West Coast Metric* in Harbor City, Ca. ![]() Marty those are the same seat emblems as mine. And the only others I've seen. My originals were shot I had a screen made and then made the buttons. Attached image(s) ![]() |
Maltese Falcon |
VW Beetle door * pulls , I had covered in black leather. Flipped over door handles...easier to actuate when the side (cage) bars are bolted in; and shorty window cranks to operate with the interior verticle bar. West Coast Metric* in Harbor City, Ca. ![]() Marty those are the same seat emblems as mine. And the only others I've seen. My originals were shot I had a screen made and then made the buttons. Get 'er Done Rory ... there was a guy in my graphic arts class (decades ago) that could free hand the Scheel logo (IMG:style_emoticons/default/pray.gif) |
Lo-Fi Version | Time is now: 30th June 2025 - 08:02 PM |
