2 Pages V < 1 2
> 914 interior fashion, RS Inner door handle a maybe.
eric9144
post Oct 22 2020, 08:39 PM
Post #21
@Maltese Falcon did you make or buy the shorty window cranks? I need those (IMG:style_emoticons/default/biggrin.gif) Can't unroll past the cage with the doors shut (IMG:style_emoticons/default/blink.gif)
Maltese Falcon
post Oct 23 2020, 10:17 AM
Post #22
QUOTE(eric9144 @ Oct 22 2020, 07:39 PM) *
Nope...I don't mfg / or sell these, but not hard to build;
Just take a couple of these (same as beetle or vanagon) , drill out the small rivet at the round knob. Remove the vinyl cover off of the handle (not reused). Measure where you will need the knob for roll bar clearence then bandsaw the Metal stem and deburr. Center punch the stem, drill a small hole / for a small screw , nut and washer, loctite.
I think that some of the VW knobs had a pop-out plastic disc...makes it easier to set the new hardware in the handle. Otherwise you will need to drill a small hole through the knob to do this.
I painted the assembly with satin black Krylon, and a bit tricky to spin>>but they work !
2 Pages V < 1 2
- Lo-Fi Version Time is now: 24th November 2026 - 05:24 AM
