> Removing, Upper strut brackets/nuts to refinish plating
shane
post Oct 17 2020, 08:51 AM
Is it possible to remove the nut/washer and the two brackets Under the three nuts on each side without the strut moving? ThanksAttached Image
ndfrigi
post Oct 17 2020, 08:55 AM
Those allen bolts holds the strut and it will change the alignment. That is where it is being align.
shane
post Oct 17 2020, 09:11 AM
QUOTE(ndfrigi @ Oct 17 2020, 07:55 AM) *
Right allen bolts don’t know why I said nuts, so I’m assuming once you remove them it will slide or something even if you don’t move anything. Just asking cause I’ve never had to remove these before. Thanks
JOEPROPER
post Oct 17 2020, 09:17 AM
The answer is "no" unless you ask...
Yes, they will move. Will need to be re-aligned even if you mark it.
ndfrigi
post Oct 17 2020, 09:19 AM
Are you planning to change your insert from the strut? If yes, you can just unbolt the center nut by using an impact wrench.
914Sixer
post Oct 17 2020, 09:39 AM
I have found IF you leave care firmly on the ground you should be replace the front first and the rear second. This is assuming you have the replacement parts BEFORE you start. Weight of car should keep strut bearing in place.
bdstone914
post Oct 17 2020, 09:50 AM
bdstone914
Take out one bolt at a time and replace with another 10mm bolt and you will not have to worry about realignment. When you do replace them permenatly use new Schnoor washers.
shane
post Oct 17 2020, 09:51 AM
QUOTE(914Sixer @ Oct 17 2020, 08:39 AM) *
Great idea I’m replating the originals so I’ll just do the fronts first then reinstall them and then do the rears. Thanks
bdstone914
post Oct 17 2020, 12:21 PM
bdstone914
QUOTE(bdstone914 @ Oct 17 2020, 08:50 AM) *
@shane
- Lo-Fi Version Time is now: 14th July 2025 - 03:46 PM
