Removing, Upper strut brackets/nuts to refinish plating |
shane |
Oct 17 2020, 08:51 AM
Member Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
914Sixer |
Oct 17 2020, 09:39 AM
914 Guru Group: Members Posts: 8,871 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I have found IF you leave care firmly on the ground you should be replace the front first and the rear second. This is assuming you have the replacement parts BEFORE you start. Weight of car should keep strut bearing in place.
shane |
Oct 17 2020, 09:51 AM
I have found IF you leave care firmly on the ground you should be replace the front first and the rear second. This is assuming you have the replacement parts BEFORE you start. Weight of car should keep strut bearing in place. Great idea I’m replating the originals so I’ll just do the fronts first then reinstall them and then do the rears. Thanks |
Lo-Fi Version | Time is now: 30th April 2024 - 05:58 AM |
