CG-914 |
Member ![]() ![]() Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California ![]() |
ALL SOLD, For sale are two things:
Pair of front 911 BOGE Struts 3 inch spacing in good condition, need to be painted. They came of an early 70s 911E. Perfect For ATE M calipers as well as Brembo Calipers. - These are a must for 5 Lug conversion. - Boge is the best choice, because you have a choice of ALL shock inserts. SOLD: A Pair of Brembo Aluminium Calipers with a set of new Hawk HPS (High Performance Street) pads. The Calpiers have the same Piston diameter as the ATE 911 S calipers, but with these advantages: - Lighter - Less flex - Cheaper - No leak issues SOLD $350 for the Brembo Calipers with Pads. These are located in OC California. Buyer is responsible for pick up or shipping cost. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,028 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Robarabian |
914 A Roo ![]() ![]() ![]() Group: Members Posts: 697 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California ![]() ![]() |
Seller: Ok, so now I'm confused. Do these bolt to a regular 911 strut, with 3 inch spacing, or are they S calipers that require the 3.5 inch spacing.
maybe a measurement photo showing the bolt spacing? |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,210 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Those Brembo calipers are not the Porsche S calipers. They should be 3" spacing to work with early 3" 911 struts.
Agree that a photo of strut ear spacing won't hurt and would be a benefit to potential buyers having once upon a time ended up with 3.5" struts that were advertised as 3". |
Literati914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,998 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
Those are most likely Brembo's off an Alfa Romeo (and are the lightest weight choice of calipers) and DO HAVE 3" mounts, and will therefore work with the 3" 911 Boge struts that are pictured. Like the 'S' calipers they would have 48mm pistons (compared to 33mm of stock 914 btw). This is a great set up, GLWS.
Edit: I see seller has corrected the description. |
Robarabian |
PM sent ref the calipers.
CG-914 |
AZBanks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,065 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region ![]() ![]() |
If you replace the word "Brembo" with "BMW" and those calipers look identical to BMW 320i calipers (which have 3 inch spacing).
CG-914 |
Those are not the same thing @AZBanks
First ATE 320i Calpers are steel and not Aluminium. Second, the Brembo can be run on 911 struts with Vented Rotors and on non vented rotors when you remove the spacers. The ATE 320i Calipers can only be run with non vented rotors. If you replace the word "Brembo" with "BMW" and those calipers look identical to BMW 320i calipers (which have 3 inch spacing). |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,854 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
I don't understand why all this confusion. (IMG:style_emoticons/default/confused24.gif)
These are the Alfa Brembos that are sought after for all the reasons exposed by the seller and the struts have their part number clearly shown. This setup is explained in the 5lug conversion thread by Eric Shea in the Classic section. I have the same setup and looking forward installing it when I convert my car to 5 lugs. GLWTS, free bump (IMG:style_emoticons/default/beerchug.gif) |
Robarabian |
purchased..
CG-914 |
CG-914 |
Alain V. |
Member ![]() ![]() Group: Members Posts: 177 Joined: 15-March 13 From: Kansas Member No.: 15,655 Region Association: None ![]() ![]() |
sending you a PM |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I don't understand why all this confusion. (IMG:style_emoticons/default/confused24.gif) These are the Alfa Brembos that are sought after for all the reasons exposed by the seller and the struts have their part number clearly shown. This setup is explained in the 5lug conversion thread by Eric Shea in the Classic section. I have the same setup and looking forward installing it when I convert my car to 5 lugs. GLWTS, free bump (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) Also note these work with 911 M-caliper rebuild kits. Except for being made of aluminum and saying brembo dimensionally they're the same as the Porsche M-caliper. It's what I have on my /6. |
Franky_Four_Fingers |
Where is the stoooone? ![]() Group: Members Posts: 19 Joined: 15-April 18 From: Chicago Member No.: 22,041 Region Association: Upper MidWest ![]() ![]() |
Interested in Struts, sent you a PM.
CG-914 |
Lo-Fi Version | Time is now: 5th July 2025 - 02:58 PM |
