SOLD: Front 911 BOGE Struts 3" and BREMBO Calipers with Hawk Pads |
CG-914 |
Oct 17 2020, 02:23 PM
Member Group: Members Posts: 323 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
ALL SOLD, For sale are two things:
Pair of front 911 BOGE Struts 3 inch spacing in good condition, need to be painted. They came of an early 70s 911E. Perfect For ATE M calipers as well as Brembo Calipers. - These are a must for 5 Lug conversion. - Boge is the best choice, because you have a choice of ALL shock inserts. SOLD: A Pair of Brembo Aluminium Calipers with a set of new Hawk HPS (High Performance Street) pads. The Calpiers have the same Piston diameter as the ATE 911 S calipers, but with these advantages: - Lighter - Less flex - Cheaper - No leak issues SOLD $350 for the Brembo Calipers with Pads. These are located in OC California. Buyer is responsible for pick up or shipping cost. |
AZBanks |
Oct 19 2020, 03:45 PM
Senior Member Group: Members Posts: 1,060 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region |
If you replace the word "Brembo" with "BMW" and those calipers look identical to BMW 320i calipers (which have 3 inch spacing).
CG-914 |
Oct 19 2020, 03:50 PM
Those are not the same thing @AZBanks
First ATE 320i Calpers are steel and not Aluminium. Second, the Brembo can be run on 911 struts with Vented Rotors and on non vented rotors when you remove the spacers. The ATE 320i Calipers can only be run with non vented rotors. If you replace the word "Brembo" with "BMW" and those calipers look identical to BMW 320i calipers (which have 3 inch spacing). |
Lo-Fi Version | Time is now: 4th May 2024 - 03:02 AM |
